NOTE:
This currently does not figure out the command, which should be easy I just havnt gotten to it yet. Currently this takes the command and figures out the most likely item as a target for that voice command
My naming scheme for groups and items is as follows.
Main group = floor
secondary group = floor_room
item name = floor_room_item
Example:
All
->upstairs
---->upstairs_lights
------->upstairs_bedroom_one_light
------->upstairs_kitchen_light
->downstairs
---->downstairs_bedroom_one
---->downstairs_bathroom
->garage
->lights
->general
At the moment it just prints out the most likely items after it is done processing.
The process
- chops up voice command
- searches top level groups and assigns points for each word in voice command found in group name
- most like groups then get searched - all members - and points are assigned to each item for each word in the command it contains
- the most likely items or groups are added to a hashmap - as long as they do not appear in the defined ignored items list
- the items in the previous hashmap then have their groups searched, assigning points for each word in the voice command found - using .groupNames
- The most likely candidates are then added to the final map and currently their names are - sorry for this in advance - println to the console.
here is the rule
some of the imports arent used… i think
This was and continues to be my everest, when I am finished it will be flawless I promise. Also please if you have any suiggestions are any ways the code can be cleaned up please do feel free to comment, it will only make it better.
import org.joda.time.*
import org.eclipse.xtext.xbase.lib.*
import org.openhab.core.persistence.*
import org.openhab.core.items.*
import org.openhab.core.library.types.*
import org.openhab.core.library.types.PercentType
import org.openhab.core.library.items.SwitchItem
import org.openhab.core.library.items.NumberItem
import org.openhab.core.library.items.GroupItem
import org.openhab.core.library.items.DimmerItem
import org.openhab.core.library.items.StringItem
import org.openhab.model.script.actions.*
import org.openhab.model.script.actions.Timer
import java.util.HashMap
import java.util.LinkedHashMap
import java.util.List
import java.util.ArrayList
import java.util.Map
import java.util.concurrent.locks.Lock
import java.util.concurrent.locks.ReentrantLock
val ArrayList<String> ignoredItems = newArrayList("upstairs_bathroom_light_state", "upstairs_kitchen_light_state", "bedroom_one_light_state", "upstairs_bathroom_light_manual_switch", "upstairs_kitchen_light_manual_override")
rule "VoiceCommand"
Item VoiceCommand received command
var String comm = "what is the temperature of the bedroom upstairs"
var String command = " " + comm + " "
//Split the voice command into an array or the different words
var String[] arr = command.replace(" in ", " ").replace(" the ", " ").replace(" on ", " ").trim.split(" ")
//Hashmap that will be used to store the points for likelyhood for each item
val HashMap<String, LinkedHashMap<String, Object>> possibleItems = new HashMap<String, LinkedHashMap<String, Object>>()
var aMembers = All?.members.map[it]
//Loop through each word in the voice command word array
for(member : aMembers) {
val LinkedHashMap<String, Object> temp1 = new LinkedHashMap<String, Object>()
for(String word : arr) {
if(member.name.contains(word)) {
if(possibleItems.get(member.name) == Uninitialized || possibleItems.get(member.name) == null) {
temp1.put("item", member)
temp1.put("possibility", 1)
possibleItems.put(member.name, temp1)
} else {
var Number poss = possibleItems.entrySet().get(member.name).get("possibility")
temp1.put("possibility", poss + 1)
val HashMap<String, Object> possibleItemsB = new HashMap<String, Object>()
for(memberB : possibleItems.entrySet()) {
val GroupItem hh = memberB.getValue().get("item") as GroupItem
hh.allMembers.forEach[e |
possibleItemsB.put(e.name, e)
val HashMap<String, LinkedHashMap<String, Object>> possibleItemsC = new HashMap<String, LinkedHashMap<String, Object>>()
for(memberC : possibleItemsB.keySet()) {
val LinkedHashMap<String, Object> temp2 = new LinkedHashMap<String, Object>()
for(String word2 : arr) {
if(memberC.contains(word2)) {
if(possibleItemsC.get(memberC) == Uninitialized || possibleItemsC.get(memberC) == null) {
temp2.put("item", possibleItemsB.get(memberC))
temp2.put("possibility", 1)
possibleItemsC.put(memberC, temp2)
} else {
val Number poss = possibleItemsC.get(memberC).get("possibility")
temp2.put("possibility", (poss))
//println(possibleItemsC)
var HashMap<String, String> winnerMap = new HashMap<String, String>()
val Number highCount = 0
val String winner = ""
for(key : possibleItemsC.keySet()) {
var Number finalPoss= possibleItemsC.get(key).get("possibility")
var Number check = 1
for(String a : ignoredItems) {
if(a.trim == key.trim) {
check = 0
if(check == 1) {
var itemasstring = possibleItemsC.get(key).get("item").toString
if(itemasstring.contains("NumberItem")) {
var NumberItem itemasitem = possibleItemsC.get(key).get("item") as NumberItem
for(String word3 : arr) {
if(itemasitem.groupNames.toString.contains(word3.trim)) {
finalPoss = finalPoss + 1
} else if(itemasstring.contains("StringItem")) {
val StringItem itemasitem = possibleItemsC.get(key).get("item") as StringItem
} else if(itemasstring.contains("DimmerItem")) {
var DimmerItem itemasitem = possibleItemsC.get(key).get("item") as DimmerItem
} else if(itemasstring.contains("SwitchItem")) {
var SwitchItem itemasitem = possibleItemsC.get(key).get("item") as SwitchItem
} else {
//println(possibleItemsB.get(memberC))
if(finalPoss > highCount) {
highCount = finalPoss
winnerMap.put(key, finalPoss)
} else if(finalPoss == highCount){
for(key : winnerMap.keySet()) {
println(key)
