Trying to develop a binding for Xiaomi Mijia Thermometer with a custom “pvvx” firmware (GitHub - pvvx/ATC_MiThermometer: Custom firmware for the Xiaomi Thermometers and Telink Flasher via USB to Serial converter). Using python “gatt” module and its “gattctl --discover” I do get the device discovered/listed. Also btmon sees some events from the device’s MAC address.
When trying to add the device as a simple “beacon” in openhab by doing a scan on the bluetooth adapter, it is not listed. Also when I add my custom handler to openhab for the device (with a manually entered MAC address) - subclass of BeaconBluetoothHandler - I do not get any events, i.e onScanRecordReceived never gets called.
When I enable TRACE logging on the bluetooth binding, none of the entries in the log relates to the device.
I’m out of ideas what could be the problem - any ideas/advice?
for reference, btmon events for the device:
> HCI Event: LE Meta Event (0x3e) plen 29 #23 [hci0] 12.394343
LE Advertising Report (0x02)
Num reports: 1
Event type: Connectable undirected - ADV_IND (0x00)
Address type: Public (0x00)
Address: A4:C1:38:AE:1F:F7 (Telink Semiconductor (Taipei) Co. Ltd.)
Data length: 17
Service Data (UUID 0x181a): a4c138ae1ff700d9215d0bdee5
RSSI: -40 dBm (0xd8)
@ MGMT Event: Device Found (0x0012) plen 31 {0x0001} [hci0] 12.478082
LE Address: A4:C1:38:AE:1F:F7 (Telink Semiconductor (Taipei) Co. Ltd.)
Flags: 0x00000000
Data length: 17
