No Charts in Sitemap after Upgrade to 4.2
I upgraded my openhab to 4.2 on my pi. Most thinks works fine. Only the Charts in the Sitemaps are empty. I use them for groups of items.
For example temperatures:
        "component": "Chart",
        "config": {
          "icon": "temperature",
          "label": "Temperaturverlauf",
          "item": "temperatures",
          "period": "W"
Basic UI in webbrowser has the same behaviour.
Screenshot_20240721-170106
“Analyse” of one of the items is empty as well.
Worked after first setup so I have not much experience with this.
Any idea?
Thanks.
I saw something in the log. I will try to fix the access rights.
2024-07-21 17:30:13.951 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/ElectricityMeter_Gesamtverbrauch.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/ElectricityMeter_Gesamtverbrauch.rrd] is not a RRD4J RRD file
Fix permissions did dot work. To speed thinks up, I Just deleted the files. Now it is working fine again.
I hope my post helps users with the same problem. Otherwise just ignore it.
