After the update in openhabian-config I cannot connect to my influxDB any more.
Trying to start influxd (in version 1.8.9) gives me:
openhabian@openHABianPi:~ $ influxd
2021-09-04T22:23:23.482863Z info InfluxDB starting {"log_id": "0WOj OaMW000", "version": "1.8.9", "branch": "1.8", "commit": "d9b56321d579"}
2021-09-04T22:23:23.483029Z info Go runtime {"log_id": "0WOjOaMW000" , "version": "go1.13.8", "maxprocs": 4}
run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
But port 8088 is not in use.
sudo netstat -lptn
[sudo] password for openhabian:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:8101 0.0.0.0:* LISTEN 651/java
tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 653/node
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 1077/smbd
tcp 0 0 0.0.0.0:5007 0.0.0.0:* LISTEN 651/java
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 651/java
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 991/lighttpd
tcp 0 0 127.0.0.1:42229 0.0.0.0:* LISTEN 651/java
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 732/sshd
tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 3462/influxd
tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 377/node-red
tcp 0 0 0.0.0.0:8443 0.0.0.0:* LISTEN 651/java
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 469/mosquitto
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 1077/smbd
tcp 0 0 0.0.0.0:10080 0.0.0.0:* LISTEN 404/inetd
tcp6 0 0 :::139 :::* LISTEN 1077/smbd
tcp6 0 0 :::80 :::* LISTEN 991/lighttpd
tcp6 0 0 :::22 :::* LISTEN 732/sshd
tcp6 0 0 :::3000 :::* LISTEN 657/grafana-server
tcp6 0 0 :::1883 :::* LISTEN 469/mosquitto
tcp6 0 0 :::445 :::* LISTEN 1077/smbd
The openhab-log gives this error:
[ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.ConnectException: Failed to connect to localhost/127.0.0.1:8086
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:831) ~[bundleFile:?]
I tried to apply some hints out of the forum with chmod, controlled my config but still the same.
I even tried to reinstall influxDB using the openhabian-config but even this ends with an error.
Any ideas? Regards, Fred
