Hi i use the influxedb persistance service in my openhab 3.4.0 container
i have installed an additional container on my qnap for the influxedb2.7.1
i made a user openhab in influxedb (login via browser is possible)
i generate an api token
afterwards i set up the infuxdb persistance service via UI as Follow
Connection
This group defines connection parameters.
Required The database URL, e.g. http://127.0.0.1:8086
Database Version
x InfluxDB 2
Required InfluxDB version
Required Database username
Database password
asdkjflakjdsflkajsdgflkjagsdflkjhasldkjfhlaksdhflasdjkfhlkasjdhfl==
The token to authenticate to database (alternative to username/password for InfluxDB 2.0)
- Database/Organization
privat
Required The name of the database (InfluxDB 1.0) or Organization for (InfluxDB 2.0)
- Retention Policy / Bucket
haus
Required The name of the retention policy (Influx DB 1.0) or bucket (InfluxDB 2.0) to write data
Additional Tags
This group defines additional tags which can be added to your measurements.
Required Should the category of the item be included as tag “category”? If no category is set, “n/a” is used.
Required Should the item type be included as tag “type”?
Required Should the item label be included as tag “label”? If no label is set, “n/a” is used.
Miscellaneous
This group defines miscellaneous parameters.
But i get the following error in log
“023-07-17 18:52:40.091 [ERROR] [.client.write.events.WriteErrorEvent] - The error occurred during writing of data
com.influxdb.exceptions.InfluxException: Connection reset”
hi now i get the data in influx but have this failure in log any suggetsions?
2023-07-23 09:09:55.099 [WARN ] [b.client.internal.InfluxDBClientImpl] - The exception occurs during check instance readiness
at com.influxdb.internal.AbstractRestClient.execute(AbstractRestClient.java:84) ~[bundleFile:?]
at com.influxdb.client.internal.InfluxDBClientImpl.ready(InfluxDBClientImpl.java:246) [bundleFile:?]
at org.openhab.persistence.influxdb.internal.influx2.InfluxDB2RepositoryImpl.connect(InfluxDB2RepositoryImpl.java:95) [bundleFile:?]
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.activate(InfluxDBPersistenceService.java:115) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:244) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:685) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:529) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:318) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:308) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:354) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:220) [org.eclipse.osgi-3.17.200.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:217) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:118) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:655) [org.eclipse.osgi-3.17.200.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2075) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2058) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:301) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:956) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:495) [org.eclipse.osgi-3.17.200.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:944) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.17.200.jar:?]
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:186) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:140) ~[?:?]
at okio.Okio$2.read(Okio.java:140) ~[bundleFile:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[bundleFile:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:358) ~[bundleFile:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:230) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readHeaderLine(Http1ExchangeCodec.java:242) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readResponseHeaders(Http1ExchangeCodec.java:213) ~[bundleFile:?]
at okhttp3.internal.connection.Exchange.readResponseHeaders(Exchange.java:115) ~[bundleFile:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
at com.influxdb.client.internal.GzipInterceptor.intercept(GzipInterceptor.java:91) ~[bundleFile:?]
at com.influxdb.client.internal.AuthenticateInterceptor.intercept(AuthenticateInterceptor.java:96) ~[bundleFile:?]
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
at com.influxdb.internal.UserAgentInterceptor.intercept(UserAgentInterceptor.java:52) ~[bundleFile:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
at com.influxdb.internal.AbstractRestClient.execute(AbstractRestClient.java:76) ~[bundleFile:?]
... 86 more
