i have a VPN from my parents home to my home. If i am at my parents house and connected to their wlan, habdroid can´t connect to my openhab server.
If i disconnect wlan and use mobile network, i can connect (with my.openhab).
Same behaviour on my workplace. VPN from work to home and no connection while in wlan of my work. If i connect to wlan of the neigbour (no vpn to my home), i can connect to my home.
Can someone help me? I think there is a bug with changing which connection habdroid should use - lokal connection or my.openhab while in a vpn network.
When i´m at my work or at my parents house, i can connect to the webfrontend of the openhab-server with a notebook without problems.
I think, habdroid doesn´t use direct connection when in a vpn. It still tries my.openhab and that doesn´t work when in local or vpn network?
I’m using ipfire with ipsec vpn, habdroid does work, but I had to change the default dns in vpn configuration at my phone (maybe configuration issue in ipsec, should be autoconfig). Even the weather widget works as expected.
I don´t use vpn connection of my phone. My phone is in the wlan at my parents house. The router of my parents is making the vpn to my home.
When i use the vpn client in my phone, everything works.
I think, habdroid is thinking, the ip adress range of my parents router is not the same as at home and so it changes to my.openhab. But with my.openhab it is not working too. If i change to wlan of the neighbour, my.openhab works. Also if i disable wlan and use mobile network, my.openhab works.
