- Platform information:
- Hardware: Proxmox server with docker inside LXC
- OS: Docker image openhab/openhab:5.1.4-debian
- Java Runtime Environment: openhab/openhab:5.1.4-debian
- openHAB version: 5.1.4
- Issue of the topic:
I have added a temperature/humidity sensor using zigbee2mqtt. Channels are ok and I can add an item. When checking “analyze” temperature is recorded with decimals; but when showing the item in page, it don’t show decimals; and trending line is not working (I don’t know if it is related I think it happend because numbers are treated without decimals).
Please post configurations (if applicable):
- Items configuration related to the issue
version: 1 things: homeassistant:device:9b1ed91559:zigbee2mqtt_5F0x00158d00023210b2: bridge: mqtt:broker:9b1ed91559 label: menjadorTemp config: topics: - sensor/0x00158d00023210b2/battery - sensor/0x00158d00023210b2/humidity - sensor/0x00158d00023210b2/linkquality - sensor/0x00158d00023210b2/pressure - sensor/0x00158d00023210b2/temperature - sensor/0x00158d00023210b2/voltage basetopic: homeassistant channels: linkquality: type: number-advanced label: Linkquality config: component: sensor nodeid: 0x00158d00023210b2 objectid: - linkquality config: - "{\"availability\":[{\"topic\":\"zigbee2mqtt/bridge/state\",\"value_template\":\"{{ value_json.state }}\"},{\"topic\":\"zigbee2mqtt/menjadorTemp/availability\",\"value_template\":\"{{ value_json.state }}\"}],\"availability_mode\":\"all\",\"default_entity_id\":\"sensor.menjadortemp_linkquality\",\"device\":{\"identifiers\":[\"zigbee2mqtt_0x00158d00023210b2\"],\"manufacturer\":\"Aqara\",\"model\":\"Temperature and humidity sensor\",\"model_id\":\"WSDCGQ11LM\",\"name\":\"menjadorTemp\",\"via_device\":\"zigbee2mqtt_bridge_0x00124b0012c38fda\"},\"enabled_by_default\":false,\"entity_category\":\"diagnostic\",\"icon\":\"mdi:signal\",\"name\":\"Linkquality\",\"object_id\":\"menjadortemp_linkquality\",\"origin\":{\"name\":\"Zigbee2MQTT\",\"sw\":\"2.11.0\",\"url\":\"https://www.zigbee2mqtt.io\"},\"state_class\":\"measurement\",\"state_topic\":\"zigbee2mqtt/menjadorTemp\",\"unique_id\":\"0x00158d00023210b2_linkquality_zigbee2mqtt\",\"unit_of_measurement\":\"lqi\",\"value_template\":\"{{ value_json[\\\"linkquality\\\"] }}\"}" temperature: type: number label: MQTT Sensor config: component: sensor nodeid: 0x00158d00023210b2 objectid: - temperature config: - "{\"availability\":[{\"topic\":\"zigbee2mqtt/bridge/state\",\"value_template\":\"{{ value_json.state }}\"},{\"topic\":\"zigbee2mqtt/menjadorTemp/availability\",\"value_template\":\"{{ value_json.state }}\"}],\"availability_mode\":\"all\",\"default_entity_id\":\"sensor.menjadortemp_temperature\",\"device\":{\"identifiers\":[\"zigbee2mqtt_0x00158d00023210b2\"],\"manufacturer\":\"Aqara\",\"model\":\"Temperature and humidity sensor\",\"model_id\":\"WSDCGQ11LM\",\"name\":\"menjadorTemp\",\"via_device\":\"zigbee2mqtt_bridge_0x00124b0012c38fda\"},\"device_class\":\"temperature\",\"enabled_by_default\":true,\"object_id\":\"menjadortemp_temperature\",\"origin\":{\"name\":\"Zigbee2MQTT\",\"sw\":\"2.11.0\",\"url\":\"https://www.zigbee2mqtt.io\"},\"state_class\":\"measurement\",\"state_topic\":\"zigbee2mqtt/menjadorTemp\",\"unique_id\":\"0x00158d00023210b2_temperature_zigbee2mqtt\",\"unit_of_measurement\":\"°C\",\"value_template\":\"{{ value_json[\\\"temperature\\\"] }}\"}" humidity: type: number label: MQTT Sensor config: component: sensor nodeid: 0x00158d00023210b2 objectid: - humidity config: - "{\"availability\":[{\"topic\":\"zigbee2mqtt/bridge/state\",\"value_template\":\"{{ value_json.state }}\"},{\"topic\":\"zigbee2mqtt/menjadorTemp/availability\",\"value_template\":\"{{ value_json.state }}\"}],\"availability_mode\":\"all\",\"default_entity_id\":\"sensor.menjadortemp_humidity\",\"device\":{\"identifiers\":[\"zigbee2mqtt_0x00158d00023210b2\"],\"manufacturer\":\"Aqara\",\"model\":\"Temperature and humidity sensor\",\"model_id\":\"WSDCGQ11LM\",\"name\":\"menjadorTemp\",\"via_device\":\"zigbee2mqtt_bridge_0x00124b0012c38fda\"},\"device_class\":\"humidity\",\"enabled_by_default\":true,\"object_id\":\"menjadortemp_humidity\",\"origin\":{\"name\":\"Zigbee2MQTT\",\"sw\":\"2.11.0\",\"url\":\"https://www.zigbee2mqtt.io\"},\"state_class\":\"measurement\",\"state_topic\":\"zigbee2mqtt/menjadorTemp\",\"unique_id\":\"0x00158d00023210b2_humidity_zigbee2mqtt\",\"unit_of_measurement\":\"%\",\"value_template\":\"{{ value_json[\\\"humidity\\\"] }}\"}" pressure: type: number label: MQTT Sensor config: component: sensor nodeid: 0x00158d00023210b2 objectid: - pressure config: - "{\"availability\":[{\"topic\":\"zigbee2mqtt/bridge/state\",\"value_template\":\"{{ value_json.state }}\"},{\"topic\":\"zigbee2mqtt/menjadorTemp/availability\",\"value_template\":\"{{ value_json.state }}\"}],\"availability_mode\":\"all\",\"default_entity_id\":\"sensor.menjadortemp_pressure\",\"device\":{\"identifiers\":[\"zigbee2mqtt_0x00158d00023210b2\"],\"manufacturer\":\"Aqara\",\"model\":\"Temperature and humidity sensor\",\"model_id\":\"WSDCGQ11LM\",\"name\":\"menjadorTemp\",\"via_device\":\"zigbee2mqtt_bridge_0x00124b0012c38fda\"},\"device_class\":\"atmospheric_pressure\",\"enabled_by_default\":true,\"object_id\":\"menjadortemp_pressure\",\"origin\":{\"name\":\"Zigbee2MQTT\",\"sw\":\"2.11.0\",\"url\":\"https://www.zigbee2mqtt.io\"},\"state_class\":\"measurement\",\"state_topic\":\"zigbee2mqtt/menjadorTemp\",\"unique_id\":\"0x00158d00023210b2_pressure_zigbee2mqtt\",\"unit_of_measurement\":\"hPa\",\"value_template\":\"{{ value_json[\\\"pressure\\\"] }}\"}" battery: type: number label: MQTT Sensor config: component: sensor nodeid: 0x00158d00023210b2 objectid: - battery config: - "{\"availability\":[{\"topic\":\"zigbee2mqtt/bridge/state\",\"value_template\":\"{{ value_json.state }}\"},{\"topic\":\"zigbee2mqtt/menjadorTemp/availability\",\"value_template\":\"{{ value_json.state }}\"}],\"availability_mode\":\"all\",\"default_entity_id\":\"sensor.menjadortemp_battery\",\"device\":{\"identifiers\":[\"zigbee2mqtt_0x00158d00023210b2\"],\"manufacturer\":\"Aqara\",\"model\":\"Temperature and humidity sensor\",\"model_id\":\"WSDCGQ11LM\",\"name\":\"menjadorTemp\",\"via_device\":\"zigbee2mqtt_bridge_0x00124b0012c38fda\"},\"device_class\":\"battery\",\"enabled_by_default\":true,\"entity_category\":\"diagnostic\",\"object_id\":\"menjadortemp_battery\",\"origin\":{\"name\":\"Zigbee2MQTT\",\"sw\":\"2.11.0\",\"url\":\"https://www.zigbee2mqtt.io\"},\"state_class\":\"measurement\",\"state_topic\":\"zigbee2mqtt/menjadorTemp\",\"unique_id\":\"0x00158d00023210b2_battery_zigbee2mqtt\",\"unit_of_measurement\":\"%\",\"value_template\":\"{{ value_json[\\\"battery\\\"] }}\"}" voltage: type: number label: MQTT Sensor config: component: sensor nodeid: 0x00158d00023210b2 objectid: - voltage config: - "{\"availability\":[{\"topic\":\"zigbee2mqtt/bridge/state\",\"value_template\":\"{{ value_json.state }}\"},{\"topic\":\"zigbee2mqtt/menjadorTemp/availability\",\"value_template\":\"{{ value_json.state }}\"}],\"availability_mode\":\"all\",\"default_entity_id\":\"sensor.menjadortemp_voltage\",\"device\":{\"identifiers\":[\"zigbee2mqtt_0x00158d00023210b2\"],\"manufacturer\":\"Aqara\",\"model\":\"Temperature and humidity sensor\",\"model_id\":\"WSDCGQ11LM\",\"name\":\"menjadorTemp\",\"via_device\":\"zigbee2mqtt_bridge_0x00124b0012c38fda\"},\"device_class\":\"voltage\",\"enabled_by_default\":true,\"entity_category\":\"diagnostic\",\"object_id\":\"menjadortemp_voltage\",\"origin\":{\"name\":\"Zigbee2MQTT\",\"sw\":\"2.11.0\",\"url\":\"https://www.zigbee2mqtt.io\"},\"state_class\":\"measurement\",\"state_topic\":\"zigbee2mqtt/menjadorTemp\",\"unique_id\":\"0x00158d00023210b2_voltage_zigbee2mqtt\",\"unit_of_measurement\":\"mV\",\"value_template\":\"{{ value_json[\\\"voltage\\\"] }}\"}"version: 1 items: menjadorTemp_temp: type: Number dimension: Temperature label: Temperatura 3 unit: °C groups: - menjador tags: - Point channel: homeassistant:device:9b1ed91559:zigbee2mqtt_5F0x00158d00023210b2:temperature- Sitemap configuration related to the issue
component: oh-label-cell config: item: menjadorTemp title: Temperatura trendItem: menjadorTemp trendSampling: 180
