Hi everyone,
I am facing the problem since approx one week that my deconz hue binding produces the following error:
2022-12-19 19:42:26.582 [WARN ] [ue.internal.handler.HueBridgeHandler] - An unexpected error occurred: No enum constant org.openhab.binding.hue.internal.State.ColorMode.2
java.lang.IllegalArgumentException: No enum constant org.openhab.binding.hue.internal.State.ColorMode.2
at java.lang.Enum.valueOf(Enum.java:240) ~[?:?]
at org.openhab.binding.hue.internal.State$ColorMode.valueOf(State.java:1) ~[bundleFile:?]
at org.openhab.binding.hue.internal.State.getColorMode(State.java:194) ~[bundleFile:?]
at org.openhab.binding.hue.internal.handler.HueBridgeHandler$2.updateGroups(HueBridgeHandler.java:304) ~[bundleFile:?]
at org.openhab.binding.hue.internal.handler.HueBridgeHandler$2.doConnectedRun(HueBridgeHandler.java:232) ~[bundleFile:?]
at org.openhab.binding.hue.internal.handler.HueBridgeHandler$PollingRunnable.run(HueBridgeHandler.java:130) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Someone else facing the problem or has an Idea what the problem is about? The issue occurred the first time I added 2 GU10 zigbee devices from Linkind to my deconz configuration. I can control the lights but sth. is not right.
My current thing config for these two new lamps
Bridge hue:bridge:XX [ ipAddress="XX", port="8081", userName="XX"]
0220 Light5_1 "Zigbee_GU10_Light6_1_li" [ lightId="26" ]
0220 Light5_2 "Zigbee_GU10_Light6_2_re" [ lightId="27" ]
corresponding items:
Group gLight5 "XX [%s]" <lightbulb> { alexa="Endpoint.Light" }
Dimmer ZigLight5_Dimmer "Dimmen" <slider> (gLight5) ["Setpoint","Light"] { alexa="PowerController.powerState,BrightnessController.brightness", channel="hue:0220:00212E03B617:Light5_1:brightness", channel="hue:0220:00212E03B617:Light5_2:brightness" }
Dimmer ZigLight5_Farbtemperatur "Farbtemperatur"<temperature> (gLight5) ["ColorTemperature"] { alexa="ColorTemperature", channel="hue:0220:00212E03B617:Light5_1:color_temperature", channel="hue:0220:00212E03B617:Light5_2:color_temperature"}
But I assume the issue is not related to the config, more to the bulb itself?! But even after deleting the two things, the issue message remains. Even if I keep only one of the approx 20 different bulbs and smart plugs, the issue is coming. Someone an idea?
Kindly,
Woogi
