I finally managed to get a “clean” login to OH (cleaned the whole browser cache and restarted Firefox) and have now also directly the “Wetterstation-neu” configuration when clicking on the HABPanel app in the Main UI:
But the gear wheel was missing while I was writing this … but when I once used the gear wheel on the top right for the HABPanel dashboard then the gear wheel beside the Date & Time in the bottom left suddenly appeared …
I take this as a success and a solution and kindly thank you for your support!!!
At least I have now a guidance what to check when the problem reoccurs!!!
I tested tonight with a clean restarted Firefox Version 87 on macos Mojave. I cleaned up the complete browser cache. I then opened the openHAB login page and logged in with my administrator userid and password => clicked in the top right to get the “App Panel” => clicked on HABPanel to start HABPanel => but no gear wheels upper right and bottom left.
I checked with the developer browser console that the session cookie is set but the token in the “Local Storage” is missing
I tried this several times cleaning the cache, logging off and on again two and three times but openhab.ui:refreshToken is still missing
I checked in the settings that that no cookies are blocked but I am not sure if the cookie settings have something to do with the token?
Does it work with the same browser on demo.openhab.org (login with demo/demo)?
Once you’re logged and go to HABPanel you should get the admin buttons and UI.
(there is no configuration, that’s normal)
Hi all,
OH3 latest stable.
How do I select alternative panel on non-admin device?
It does show the default one (the one which has “star” on the admin device).
If I assign a start to another panel config, non-admin device panel remains the same it was before.
In any case, my goal is to have several devices running different panels, stored on a server.
I found out that you need to login to the Main-UI once ON THIS DEVICE, and then go back to Habpanel and then you see the gear icon and can choose a different panel or whatever.
Hi. Can I just say the AdblockPlus will definitely exhibit this behaviour. I’ve just disabled it for my new install and the Habpanel is now configurable. Cheers
