I have installed Openhab3 with Openhabian and additionally influx and grafana using the openhabian config.
How can I check that the configuration was sucessfull and my items are persisted according to my influxdb.persist file?
If I enter “SHOW MEASUREMENTS ON openhab” in the influx console I get no result
In the OH system log the only thing about influx I see is:
Loading model ‘influxdb.persist’
Confirm those items are groups, otherwise nothing will get persisted.
Although your direct request may already gave the correct result you could also try the get the hopefully persisted data via a REST call ( call API Exolorer under OH3).
Using the same group in the API explorer you can also request a list of the installed persistence services. Maybe a typing error or uppercase DB? (I don’t use this DB).
