- Platform information:
- Hardware: x86
- OS: Ubuntu 16.04
- Java Runtime Environment: zulu-8/oracle-java-8
- openHAB version: 2.2.0
- Issue of the topic: can’t get any java audio from openhab
I’m trying to get openhab to play audio or do TTS (using MaryTTS) for a few days now, but I can’t get any audio from it (apart from webaudio).
Initally I installed openhab with oracle-java-8 on my Ubuntu server and had no openhab audio. I played with the sound.properties file in the /usr/lib/jvm/… sub folder, but I couldn’t fix it with the settings for icedtea sound or sun media. I’ve installed libpulse-java and libpulse-jni as well and I’m now using the zulu-8 jre.
Yesterday I managed to play a wav file with a small java application on the command line and while playing, it appeared as using the [ALSA plugin] in pavucontrol (pulseaudio mixer gui). Openhab still is completely silent. When I play the doorbell file from the openhab-cli or use the say command it looks like it’s doing something (small delay before the prompt comes back), but I still don’t hear anything and there’s nothing in the logs (openhab and event log).
Any help or hint is much appreciated!
Cheers, Alex
