I was trying to debug a wall button, on which the lamps sometimes do not react. I have debug on, I looked at the openhab.log file, and I looked to that log via the nice zwave logfile viewer site Z-Wave Log Viewer from @chris. Still using OH2.12 on Openhabian, but the logfiles seems pretty much the same in OH3.
The rule reacts on the push of a button (Aeotec Wallmote, node 3) and puts the dimmer (node 5) of the lamp ON. Fairly simple. The logfile processed by the Zwave viewer looks OK:
Seems fine, button 3 is pressed, then the dimmer is switched off, and it replies with some messages, among which a new amount of Watts used.
- Is this the correct interpretation?
However, I was suspicious because I see that the messages are placed in the queue, according to the line at 21:40:43.949.
- What queue is that?
- There is polling later on, is that something to be worried about?
2021-09-25 21:40:43.828 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 3: Received scene 3 at key 0 [Single Press]
2021-09-25 21:40:43.831 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-09-25 21:40:43.833 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CENTRAL_SCENE, value=3.0
2021-09-25 21:40:43.836 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:374344a4:node3:scene_number to 3.0 [DecimalType]
2021-09-25 21:40:43.841 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2021-09-25 21:40:43.845 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b95d87.
2021-09-25 21:40:43.847 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-09-25 21:40:43.849 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-09-25 21:40:43.851 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-09-25 21:40:43.851 [INFO ] [se.smarthome.model.script.Rule LA-WB] - lamps switched using wallmote
2021-09-25 21:40:43.852 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-09-25 21:40:43.937 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Command received zwave:device:374344a4:node5:switch_dimmer --> OFF [OnOffType]
2021-09-25 21:40:43.940 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Creating new message for command SWITCH_MULTILEVEL_SET
2021-09-25 21:40:43.942 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2021-09-25 21:40:43.944 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2021-09-25 21:40:43.946 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2021-09-25 21:40:43.949 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Added 316 to queue - size 2
2021-09-25 21:40:43.952 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-09-25 21:40:43.955 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 05 03 26 01 00 25 61 83
2021-09-25 21:40:43.961 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0A 00 13 05 03 26 01 00 25 61 83
2021-09-25 21:40:43.967 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-09-25 21:40:43.969 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-09-25 21:40:43.970 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Command received zwave:device:374344a4:node6:switch_dimmer --> OFF [OnOffType]
2021-09-25 21:40:43.971 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-09-25 21:40:43.973 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 6: Creating new message for command SWITCH_MULTILEVEL_SET
2021-09-25 21:40:43.973 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-09-25 21:40:43.974 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-09-25 21:40:43.974 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2021-09-25 21:40:43.976 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-09-25 21:40:43.976 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2021-09-25 21:40:43.979 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-09-25 21:40:43.989 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-09-25 21:40:43.991 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 316: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 97
2021-09-25 21:40:43.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: Adding to device queue
2021-09-25 21:40:43.994 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling initialised at 1800 seconds - start in 1500 milliseconds.
2021-09-25 21:40:43.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: Added 317 to queue - size 2
2021-09-25 21:40:43.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-09-25 21:40:43.999 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling initialised at 1800 seconds - start in 1500 milliseconds.
2021-09-25 21:40:43.999 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-09-25 21:40:44.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-09-25 21:40:44.022 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-09-25 21:40:44.024 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 316: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 97
2021-09-25 21:40:44.024 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 61 00 00 02 00 C7 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 51
2021-09-25 21:40:44.027 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-09-25 21:40:44.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 316: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 97
2021-09-25 21:40:44.031 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-09-25 21:40:44.033 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: sentData successfully placed on stack.
2021-09-25 21:40:44.035 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 316: Advanced to WAIT_REQUEST
2021-09-25 21:40:44.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: TID 316: Transaction not completed
2021-09-25 21:40:44.040 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-09-25 21:40:44.042 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-09-25 21:40:44.050 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=97, payload=61 00 00 02 00 C7 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-09-25 21:40:44.053 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=97, payload=61 00 00 02 00 C7 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2021-09-25 21:40:44.055 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 316: [WAIT_REQUEST] priority=Set, requiresResponse=true, callback: 97
2021-09-25 21:40:44.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-09-25 21:40:44.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 316: [WAIT_REQUEST] priority=Set, requiresResponse=true, callback: 97
2021-09-25 21:40:44.060 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 316: (Callback 97)
2021-09-25 21:40:44.062 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-09-25 21:40:44.064 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 316: callback 97
Thanks for your help!
