Hi
I just upgraded from 1.8.0 to 1.8.3. I had some sliders that were working fine both in iOS and the Classic UI, but after the upgrade, they only work in iOS and in the browser they are rendered as setpoints. And in the Classic UI, they do nothing. It doesn’t matter if it is a long or short click.
I’ve searched the forum and found nothing. In the 1.8.2 release notes I’ve seen that the slider was removed (https://github.com/openhab/openhab/pull/4051), but shouldn’t the setpoint render work? Am I doing anything wrong?
Regards.
Thank you! The problem was that with the slider render you receive the decimal value with the event, and with the setpoint render you receive an INCREASE/DECREASE event, so you have to update de value manually just as in the demo.
