No SNAPSHOT after MILESTONE
After reaching the milestone a few days ago I was not getting any snapshot updates anymore
After forcing an install the apt utility thinks that the snapshot is a downgrade!
openhab@openhab:~$ sudo apt install openhab2=2.4.0~20180908115850-1
Reading package lists... Done
Building dependency tree
The following packages will be DOWNGRADED:
  openhab2
0 to upgrade, 0 to newly install, 1 to downgrade, 0 to remove and 0 not to upgrade.
Are the versions in the right order in the repo?
openhab@openhab:~$ sudo apt-cache madison openhab2
  openhab2 | 2.4.0~20180908115850-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180908115850-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180908034039-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180908034039-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180908031533-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180908031533-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180907034303-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180907034303-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180906111426-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180906111426-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180904183712-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180904183712-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180904031505-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180904031505-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180902221416-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180902221416-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180902031432-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180902031432-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.4.0~20180831210140-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.4.0~20180831210140-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 |    2.3.0-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 |    2.3.0-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.3.0~RC2-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.3.0~RC2-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 | 2.3.0~RC1-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 | 2.3.0~RC1-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 |    2.2.0-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 |    2.2.0-1 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
  openhab2 |    2.1.0-2 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
  openhab2 |    2.1.0-2 | https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main i386 Packages
Yes, that’s correct. The milestone was published falsely (at the wrong channel, should have been testing)
See openHAB Milestone builds for details.
Thanks @Udo_Hartmann, you’re on the ball today!!
I should have searched the forum!!
Hi together,
i’m a little bit confused.
Time ago installed the Version “openHAB 2.4.0~20180626235718-1 (Build #1304)” with openhbian-config.
I actually want to update to latest 2.4 M… Version.
But when i show the available list with: sudo apt-cache madison openhab2
i got only this one:
openhab2 | 2.3.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.2.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.1.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.0.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Package
Can anyone help me how can i install the newest 2.4 M Version ?
Many Thanks
Christian
Edit: I was a little too fast. I found the right way to bring it up to the actual Release with openhabian-config.
