Openhab does not run anymore because of missing space on device.
df -h shows that /dev/root is 100% in use and i dont know why. Also i cant find out, what exactly grew this much.
It runs on Raspberry with openhabian, Openhab 3.5.
any idea?
any idea?
Something has written to disk until it got full. Are you sure it’s /dev/root? I have a recent openHABian and there is no such file system.
huginn rich ~ 18:47
df -h
Filesystem Size Used Avail Use% Mounted on
udev 327M 0 327M 0% /dev
tmpfs 93M 2.0M 91M 3% /run
/dev/mmcblk0p2 29G 12G 16G 43% /
tmpfs 461M 0 461M 0% /dev/shm
tmpfs 5.0M 16K 5.0M 1% /run/lock
/dev/mmcblk0p1 510M 95M 416M 19% /boot/firmware
/dev/zram1 336M 2.1M 307M 1% /opt/zram/zram1
/dev/zram2 452M 55M 363M 14% /opt/zram/zram2
tmpfs 93M 0 93M 0% /run/user/1000
overlay2 452M 55M 363M 14% /var/log
overlay1 336M 2.1M 307M 1% /var/lib/openhab/persistence
Notice that the root of the file system appears in the last column. That might give a clue.
The following command will give the top five directories by size in <path>
du -a <path> | sort -n -r | head -n 5
Replace <path>
with the value under “mounted on” in the game returned by df
that corresponds to the full file system.
