For all bundles I get the following message after upgrading to the latest snapshot of today.
- Platform information:
- Hardware: Raspberry PI 3
- OS: openhabian
- Java Runtime Environment: openjdk version “1.8.0_152”
- openHAB version: openHAB 2.2.0 Build #1099
- Issue of the topic:
- The issue is that I get a lot of INFO as seen in the log below.
- If logs where generated please post these here using code fences:
2017-11-30 17:18:58.515 [INFO ] [org.knowm.yank.YankPoolManager ] - Initialized pool 'yank-default'
2017-11-30 17:19:04.271 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - Bundle Considered for SPI providers: org.openhab.persistence.jdbc
2017-11-30 17:19:04.276 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - No 'SPI-Provider' Manifest header. Skipping bundle: org.openhab.persistence.jdbc
2017-11-30 17:19:05.280 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - Bundle Considered for SPI providers: org.openhab.persistence.mapdb
2017-11-30 17:19:05.285 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - No 'SPI-Provider' Manifest header. Skipping bundle: org.openhab.persistence.mapdb
2017-11-30 17:19:05.381 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - Bundle Considered for SPI providers: org.openhab.persistence.mqtt
2017-11-30 17:19:05.385 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - No 'SPI-Provider' Manifest header. Skipping bundle: org.openhab.persistence.mqtt
And this goes on for all other bundles as well.
2017-11-30 17:19:06.044 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-11-30 17:19:06.086 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - Bundle Considered for SPI providers: org.openhab.ui.habpanel
2017-11-30 17:19:06.089 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - No 'SPI-Provider' Manifest header. Skipping bundle: org.openhab.ui.habpanel
2017-11-30 17:19:06.497 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.openhab.core_2.2.0.201711260007 [190]] to http service
2017-11-30 17:19:06.539 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-11-30 17:19:06.590 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.openhab.core_2.2.0.201711260007 [190], contextID=default], with context-name:
2017-11-30 17:19:06.632 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core_2.2.0.201711260007 [190], contextID=default]}
2017-11-30 17:19:08.653 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - Bundle Considered for SPI providers: org.openhab.core
2017-11-30 17:19:08.660 [INFO ] [g.apache.aries.spifly.dynamic.bundle] - No 'SPI-Provider' Manifest header. Skipping bundle: org.openhab.core
The last lines above are the last lines in the openhab.log and whatever I do in any of the UI’s nothing happens or gets added to the log.
And below some info from openhab-cli.
Version: 2.2.0-SNAPSHOT (#1099)
User: openhab (Active Process 5364)
User Groups: openhab tty dialout gpio
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhabian
OPENHAB_CONF | /etc/openhab2 | openhab:openhabian
OPENHAB_LOGDIR | /var/log/openhab2 | openhab:openhabian
Dashboard URLs: http://192.168.1.13:8080
https://192.168.1.13:8443
The result is that OpenHAB does not receive any data from my things and cannot send commands to my things.
Thanks in advance.
