i saw the possibility of an update to 2.5.5 from Version before and do it without any backup. After I realized that I couldn’t access to my HABPanel I noticed that I have to choose the “expert-mode” again but clicked on simple. Now I do not have any UI and couldn’t access to my old HABPanel.
I have edited and deleted “addons.cfg” but that doesn’t take effect. Could you please help me get my old configurations working?
Best regards
Chris
TOPIC WAS CLOSED AND I COULDN’T REPLY BUT MAKE THIS ADDITION:
The issue comes more often after the great solution from Wolfgang_S. When i began to work with OpenHAB i’ve installed it on ubuntu via the software AND (i don’t know why) via commandline. There were a lot more problems so i’ve deleted absolutely all and started completely new. A new installation of ubuntu and a proper installation of OpenHAB an all the bindings. Now everything works fine.
If you clicked on simple package you should have at least PaperUI and HABPanel.
From which version did you update ?
Are there any errror messages in the log files ?
What kind of message/page do you get when you try to access openhab via browser ?
the openhab / karaf console provides a command line interface.
In case your installation still is configurable via the command line interface you might be able to add / install the missing UIs.
Please also have a look at the log files in /var/log/openhab/ to check if there is any error message.
[ERROR] [.service.internal.HttpServiceStarted] - Could not start the servlet context for context path []
org.eclipse.jetty.util.MultiException: Multiple exceptions
There are a few Errors like this:
Caused by: java.net.BindException: Die Adresse wird bereits verwendet
