No value in Item for Danfoss Popp Thermostat Zwave
After upgrading OpenHab from 2.3 to 2.4 I have a few issues with zwave devices.
I removed all Things and reinstalled them.
In 2.3 my 2 Danfoss Popp thermostates worked perfectly, but after upgrading they don’t seem to update.
They were properly recognised as ‘010101 Popp Wireless Thermostatic Valve TRV’ but the Items don’t change and sending updates doesn’t seem to work.
I updated polling to every 10 minutes to hopefully see some results.
Below my (filtered) log:
2019-01-10 13:28:35.704 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:35.706 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:35.709 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2019-01-10 13:28:35.711 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:35.713 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_BATTERY V0 BATTERY_REPORT
2019-01-10 13:28:35.715 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 11: Battery report value = 58
2019-01-10 13:28:35.718 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:35.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@653e84.
2019-01-10 13:28:35.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:35.837 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:35.839 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:35.841 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:35.844 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:35.846 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:35.848 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:35.850 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:35.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:35.855 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@148d05b.
2019-01-10 13:28:36.063 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:36.065 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:36.067 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_CLIMATE_CONTROL_SCHEDULE, endpoint 0
2019-01-10 13:28:36.070 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:36.072 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_CLIMATE_CONTROL_SCHEDULE V0 SCHEDULE_OVERRIDE_REPORT
2019-01-10 13:28:36.074 [INFO ] [veClimateControlScheduleCommandClass] - NODE 11 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2019-01-10 13:28:36.076 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:36.078 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1054027.
2019-01-10 13:28:36.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:36.183 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:36.185 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2019-01-10 13:28:36.186 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:36.188 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
2019-01-10 13:28:36.190 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Type = Temperature(1), Scale = 0
2019-01-10 13:28:36.192 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Value = 11.59
2019-01-10 13:28:36.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:36.196 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@ad61ad.
2019-01-10 13:28:36.363 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:36.366 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:36.368 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Is awake with 3 messages in the queue
2019-01-10 13:28:36.370 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Start sleep timer at 1000ms
2019-01-10 13:28:36.373 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 11: Node Status event - Node is AWAKE
2019-01-10 13:28:36.377 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:36.379 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@127f322.
2019-01-10 13:28:36.391 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 09 00 13 0B 02 31 04 25 86 7A
2019-01-10 13:28:36.467 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2019-01-10 13:28:36.475 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 68108: Transaction not completed
2019-01-10 13:28:36.714 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:36.715 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:36.717 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2019-01-10 13:28:36.718 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:36.720 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
2019-01-10 13:28:36.721 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Type = Temperature(1), Scale = 0
2019-01-10 13:28:36.723 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Value = 11.59
2019-01-10 13:28:36.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:36.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5e2f15.
2019-01-10 13:28:36.873 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 3 Messages waiting, state DONE
2019-01-10 13:28:37.374 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 3 Messages waiting, state DONE
2019-01-10 13:28:37.475 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:37.477 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:37.478 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2019-01-10 13:28:37.480 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:37.481 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
2019-01-10 13:28:37.483 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Type = Temperature(1), Scale = 0
2019-01-10 13:28:37.484 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Value = 11.59
2019-01-10 13:28:37.486 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:37.493 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1f35b41.
2019-01-10 13:28:37.572 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 134, Status = Transmission complete and ACK received(0)
2019-01-10 13:28:37.574 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:37.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 68108: Transaction not completed
2019-01-10 13:28:37.703 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:37.704 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:37.706 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2019-01-10 13:28:37.707 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:37.708 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
2019-01-10 13:28:37.710 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Type = Temperature(1), Scale = 0
2019-01-10 13:28:37.712 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Sensor Value = 11.59
2019-01-10 13:28:37.713 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:37.715 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@d0efdb.
2019-01-10 13:28:37.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@d0efdb.
2019-01-10 13:28:37.718 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:68108 DONE
2019-01-10 13:28:37.729 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 43 02 01 25 87 0C
2019-01-10 13:28:37.814 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2019-01-10 13:28:37.818 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 68109: Transaction not completed
2019-01-10 13:28:37.873 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 2 Messages waiting, state DONE
2019-01-10 13:28:38.225 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:38.227 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:38.230 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:38.232 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:38.234 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:38.237 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:38.239 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:38.241 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:38.243 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:38.245 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@a2bf40.
2019-01-10 13:28:38.373 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 2 Messages waiting, state DONE
2019-01-10 13:28:38.874 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 2 Messages waiting, state DONE
2019-01-10 13:28:38.905 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:38.907 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:38.910 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:38.912 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:38.914 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:38.916 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:38.918 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:38.921 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:38.923 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:38.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1350a06.
2019-01-10 13:28:39.374 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 2 Messages waiting, state DONE
2019-01-10 13:28:39.806 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:39.808 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:39.810 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:39.813 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:39.815 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:39.817 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:39.819 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:39.827 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:39.837 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:39.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6f72f2.
2019-01-10 13:28:39.874 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 2 Messages waiting, state DONE
2019-01-10 13:28:39.961 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:39.963 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:39.966 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:39.968 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:39.970 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:39.972 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:39.974 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:39.977 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:39.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:39.985 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@12ce793.
2019-01-10 13:28:39.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:39.999 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.002 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:40.004 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:40.021 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:40.028 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:40.030 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:40.033 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:40.036 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:40.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@c71149.
2019-01-10 13:28:40.052 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:40.054 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.056 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:40.059 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:40.061 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:40.065 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:40.067 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:40.069 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:40.071 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:40.073 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@11d492d.
2019-01-10 13:28:40.185 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:40.188 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.190 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:40.192 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:40.201 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:40.203 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:40.206 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:40.208 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:40.211 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:40.214 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@fa439e.
2019-01-10 13:28:40.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:40.268 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.271 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:40.273 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:40.277 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:40.280 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:40.282 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:40.285 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:40.287 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:40.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@43f2d.
2019-01-10 13:28:40.375 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 2 Messages waiting, state DONE
2019-01-10 13:28:40.445 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:40.447 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.449 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:40.451 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:40.453 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:40.456 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:40.458 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:40.460 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:40.462 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:40.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4b25bd.
2019-01-10 13:28:40.535 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:40.537 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.540 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:40.543 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:40.545 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:40.551 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:40.556 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:40.559 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:40.561 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:40.564 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1705e78.
2019-01-10 13:28:40.650 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 135, Status = Transmission complete and ACK received(0)
2019-01-10 13:28:40.656 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 68109: Transaction not completed
2019-01-10 13:28:40.682 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:40.684 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.687 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:28:40.689 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:40.692 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:28:40.694 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:28:40.697 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:28:40.699 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:28:40.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:40.704 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1de087b.
2019-01-10 13:28:40.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1de087b.
2019-01-10 13:28:40.709 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:68109 DONE
2019-01-10 13:28:40.727 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 09 00 13 0B 02 80 02 25 88 C3
2019-01-10 13:28:40.808 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2019-01-10 13:28:40.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 68110: Transaction not completed
2019-01-10 13:28:40.849 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 136, Status = Transmission complete and ACK received(0)
2019-01-10 13:28:40.852 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.856 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 68110: Transaction not completed
2019-01-10 13:28:40.871 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:28:40.874 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 1 Messages waiting, state DONE
2019-01-10 13:28:40.874 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:40.877 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2019-01-10 13:28:40.881 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:40.884 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_BATTERY V0 BATTERY_REPORT
2019-01-10 13:28:40.886 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 11: Battery report value = 58
2019-01-10 13:28:40.888 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:28:40.890 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@76a83a.
2019-01-10 13:28:40.892 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@76a83a.
2019-01-10 13:28:40.894 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:68110 DONE
2019-01-10 13:28:41.375 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 0 Messages waiting, state DONE
2019-01-10 13:28:41.874 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: WakeupTimerTask 0 Messages waiting, state DONE
2019-01-10 13:28:41.876 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: No more messages, go back to sleep
2019-01-10 13:28:41.878 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 11: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2019-01-10 13:28:41.881 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:28:41.884 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2019-01-10 13:28:41.886 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@147d716
2019-01-10 13:28:41.890 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Bump transaction 68139 priority from Immediate to Immediate
2019-01-10 13:28:41.893 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2019-01-10 13:28:41.896 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 68139 to queue - size 6
2019-01-10 13:28:41.905 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 09 00 13 0B 02 84 08 25 89 CC
2019-01-10 13:28:41.997 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2019-01-10 13:28:42.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 68139: Transaction not completed
2019-01-10 13:28:42.045 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 137, Status = Transmission complete and ACK received(0)
2019-01-10 13:28:42.048 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:28:42.053 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Response processed after 113ms
2019-01-10 13:28:42.056 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 68139: Transaction completed
2019-01-10 13:28:42.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:68139 DONE
2019-01-10 13:28:42.071 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Went to sleep COMPLETE
2019-01-10 13:29:47.487 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Command received zwave:device:8a85845d:node11:thermostat_setpoint_heating → 11 °C [QuantityType]
2019-01-10 13:29:47.491 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 11: Thermostat command received for 11 °C
2019-01-10 13:29:47.493 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Creating new message for command THERMOSTAT_SETPOINT_SET
2019-01-10 13:29:47.508 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:29:47.510 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT is NOT required to be secured
2019-01-10 13:29:47.512 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 11: Sending Message: org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@861a86
2019-01-10 13:29:47.515 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Creating new message for application command THERMOSTAT_SETPOINT_GET (Heating)
2019-01-10 13:29:47.518 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:29:47.520 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT is NOT required to be secured
2019-01-10 13:29:47.524 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Bump transaction 68143 priority from Set to Immediate
2019-01-10 13:29:47.527 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2019-01-10 13:29:47.529 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 68143 to queue - size 6
2019-01-10 13:29:47.534 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Bump transaction 68144 priority from Get to Immediate
2019-01-10 13:29:47.536 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2019-01-10 13:29:47.541 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 68144 to queue - size 7
2019-01-10 13:29:47.546 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling intialised at 600 seconds - start in 1500 milliseconds.
2019-01-10 13:29:49.046 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling…
2019-01-10 13:29:49.048 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:8a85845d:node11:sensor_temperature
2019-01-10 13:29:49.050 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 11: Generating poll message for COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2019-01-10 13:29:49.052 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 11: Creating new message for command SENSOR_MULTILEVEL_GET
2019-01-10 13:29:49.055 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:29:49.057 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_SENSOR_MULTILEVEL is NOT required to be secured
2019-01-10 13:29:49.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:8a85845d:node11:thermostat_setpoint_heating
2019-01-10 13:29:49.062 [DEBUG] [ter.ZWaveThermostatSetpointConverter] - NODE 11: Generating poll message for COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:29:49.064 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Creating new message for application command THERMOSTAT_SETPOINT_GET (Heating)
2019-01-10 13:29:49.067 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:29:49.069 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_THERMOSTAT_SETPOINT is NOT required to be secured
2019-01-10 13:29:49.072 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling zwave:device:8a85845d:node11:battery-level
2019-01-10 13:29:49.074 [DEBUG] [rnal.converter.ZWaveBatteryConverter] - NODE 11: Generating poll message for COMMAND_CLASS_BATTERY endpoint 0
2019-01-10 13:29:49.077 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:29:49.080 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
2019-01-10 13:29:49.083 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Bump transaction 68145 priority from Get to Immediate
2019-01-10 13:29:49.085 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2019-01-10 13:29:49.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 68145 to queue - size 8
2019-01-10 13:29:49.097 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Bump transaction 68146 priority from Get to Immediate
2019-01-10 13:29:49.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2019-01-10 13:29:49.102 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Transaction already in queue - removed original
2019-01-10 13:29:49.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 68146 to queue - size 8
2019-01-10 13:29:49.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Bump transaction 68147 priority from Get to Immediate
2019-01-10 13:29:49.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2019-01-10 13:29:49.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 68147 to queue - size 9
2019-01-10 13:38:19.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:38:19.138 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:38:19.141 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2019-01-10 13:38:19.144 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:38:19.146 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_BATTERY V0 BATTERY_REPORT
2019-01-10 13:38:19.149 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 11: Battery report value = 58
2019-01-10 13:38:19.151 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
2019-01-10 13:38:19.154 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@270c3e.
2019-01-10 13:38:19.297 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Application Command Request (ALIVE:DONE)
2019-01-10 13:38:19.306 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: resetResendCount initComplete=true isDead=false
2019-01-10 13:38:19.311 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Incoming command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0
2019-01-10 13:38:19.314 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2019-01-10 13:38:19.317 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 11: Received COMMAND_CLASS_THERMOSTAT_SETPOINT V0 THERMOSTAT_SETPOINT_REPORT
2019-01-10 13:38:19.320 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint report Scale = 0
2019-01-10 13:38:19.324 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Value = 10.5
2019-01-10 13:38:19.330 [DEBUG] [.ZWaveThermostatSetpointCommandClass] - NODE 11: Thermostat Setpoint Report, Type Heating (1), value = 10.5
2019-01-10 13:38:19.333 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Commands processed 1.
On https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/449 it looks likes there might be something wrong?
How can I (help) fix it and have my thermostates work again properly?
I am using Openhabian on a rasberry Pi3.
Hi Please Read.
This Just makes it easier for analysing . can we have more details of your setup.
Hi, I’m sorry the log turned out that long in the post, but I did use the code fences …
Like I mentioned in my first post, I have a Raspberry Pi3 with the latest release of Openhabian, running openhab 2.4.0. As a zwave serial controller I have Razberry (v1).
All worked perfectly fine in Openhab 2.3 and I received regular updates on the SensorTemperature from the Popp Thermostate.Any more details you need?
No you didn’t. Otherwise the log would have appeared as
2019-01-10 13:29:47.487 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Command received zwave:device:8a85845d:node11:thermostat_setpoint_heating --> 11 °C [QuantityType]
Just to rule out the obvious parts, all of your Things have identical IDs after recreating them? Check for typos in the link to the Items.
Which code fence did you use?
I wrote
<code>
Pasted log
</code>
But that does only seem to affect the font, not the scrolling.
Yes, I used paperUI to create them and all USE the same ID
Those are (re)created with paperUI too.
You didn’t read the link.<code> is not a supported tag on this forum. At least it’s not what we mean by code fences. See the link for supported code fences.
Just to make sure, even the randomly generated part of the ID that comes from the Serial Thing that represents the Zwave Controller?
OK, that probably rules out a messed up Link. I’ll be of no more help.
