No viable alternative at input 'between'
After upgrading Openhabian 5.2.0~S5361-1 over 5.2.0~S5155-1 some of my dsl.rule files failed to load.
I found the cause to be the following line:
var myVar = java.time.Duration.between(myItem.lastUpdate(), now).toDays()
I think the DSL parser has changed and it now sees “between” as a built-in language feature rather than a java method name.
I tired the following double colon syntax as follows and that did not work:
var myVar = java.time.Duration::between(myItem.lastUpdate(), now).toDays()
Using a explicit Namespace has worked, however it does make a lot of my scripts harder to read:
val myVar = (java.time.Duration.getDeclaredMethod(“between”, java.time.temporal.Temporal, java.time.temporal.Temporal).invoke(null, myItem.lastUpdate(), now) as java.time.Duration).toDays()
Is this a bug that should be fixed our is there a more efficient way for me to calculate the number of days/hours since an item has been updated?
Thanks,
Harjit
Just try to use an exponent-sign e.g.
var myVar = java.time.Duration.^between(myItem.lastUpdate(), now).toDays()
and have a look on this thread
Hope this can help
Cheers - Peter
It has been fixed. Try with a more recent snapshot.
I upgraded from 5.2.0~S5361-1 to 5.2.0~S5375-1 and that resolved the issue. Thank you
