I’ve got a few Leviton RZI06-1L switches that I’m trying to add. They are not in the database and unfortunately OH did not create node XML file when I tried to add one.
I’ve tried this with both stable and snapshot versions. It’s running on an RPi 3 using the aeon gen5 z-stick.
Can anyone tell from the portion of my log below why OH is not able to create the XML file?
The Leviton is Node 13.
2018-07-15 20:15:59.086 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Unknown command class 0x91
2018-07-15 20:15:59.387 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Unknown command class 0x91
2018-07-15
20:15:59.558 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 13:
Device discovery could not resolve to a thingType! 001D:0401:0206::0.3
2018-07-15
20:15:59.566 [INFO ] [g.discovery.internal.PersistentInbox] - Added new
thing 'zwave:device:e6edcb03:node13' to inbox.
2018-07-15
20:16:03.078 [ERROR] [nal.common.AbstractInvocationHandler] - An error
occurred while calling method 'ThingHandler.dispose()' on
'org.openhab.binding.zwave.handler.ZWaveThingHandler@138d1fd': null
at
org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeSerializer.SerializeNode(ZWaveNodeSerializer.java:97)
[199:org.openhab.binding.zwave:2.4.0.201807141304]
at
org.openhab.binding.zwave.handler.ZWaveThingHandler.dispose(ZWaveThingHandler.java:478)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:497) ~[?:?]
at
org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153)
[94:org.eclipse.smarthome.core:0.10.0.201807081340]
at
org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
at java.lang.Thread.run(Thread.java:745) [?:?]
2018-07-15
20:16:03.083 [ERROR] [ome.core.thing.internal.ThingManager] - Exception
occurred while disposing handler of thing
'zwave:device:e6edcb03:node6': null
at
at
at
at
2018-07-15
20:16:09.911 [ERROR] [nal.common.AbstractInvocationHandler] - An error
'org.openhab.binding.zwave.handler.ZWaveThingHandler@1895b07': null
at
at
at
at
2018-07-15
20:16:09.922 [ERROR] [ome.core.thing.internal.ThingManager] - Exception
'zwave:device:e6edcb03:node7': null
at
at
at
at
2018-07-15
20:16:17.325 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 10:
Device discovery could not resolve to a thingType! 0005:4841:0018::10.0
2018-07-15
20:16:17.349 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 13:
