Hi, I am creating a new binding (GitHub - austvik/openhab-addons at airgradient), but when I try to add discovery to it, I get the following error:
java.lang.NoClassDefFoundError: org/openhab/core/config/discovery/AbstractThingHandlerDiscoveryService
at java.lang.ClassLoader.defineClass1(Native Method) ~[?:?]
at java.lang.ClassLoader.defineClass(ClassLoader.java:1017) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:283) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:716) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:639) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:607) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:587) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:566) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:335) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:397) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:500) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:416) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:168) ~[org.eclipse.osgi-3.18.0.jar:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:525) ~[?:?]
at org.openhab.binding.airgradient.internal.handler.AirGradientAPIHandler.getServices(AirGradientAPIHandler.java:226) ~[?:?]
at org.openhab.core.thing.binding.BaseThingHandlerFactory.registerServices(BaseThingHandlerFactory.java:146) ~[?:?]
at org.openhab.core.thing.binding.BaseThingHandlerFactory.registerHandler(BaseThingHandlerFactory.java:140) ~[?:?]
at org.openhab.core.thing.internal.ThingManagerImpl.doRegisterHandler(ThingManagerImpl.java:531) ~[?:?]
at org.openhab.core.thing.internal.ThingManagerImpl.registerHandler(ThingManagerImpl.java:512) ~[?:?]
at org.openhab.core.thing.internal.ThingManagerImpl.registerAndInitializeHandler(ThingManagerImpl.java:927) ~[?:?]
at org.openhab.core.thing.internal.ThingManagerImpl.checkMissingPrerequisites(ThingManagerImpl.java:1124) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
Caused by: java.lang.ClassNotFoundException: org.openhab.core.config.discovery.AbstractThingHandlerDiscoveryService cannot be found by org.openhab.binding.airgradient_4.2.0.202402011930
at org.eclipse.osgi.internal.loader.BundleLoader.generateException(BundleLoader.java:541) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:487) ~[org.eclipse.osgi-3.18.0.jar:?]
What I have done:
- Installed OpenHab 4.1.1 on a linux box
- Compiled my binding (GitHub - austvik/openhab-addons at airgradient) which is on the most up to date openhab-addons from today
- Copied the jar file (org.openhab.binding.airgradient-4.2.0-SNAPSHOT.jar) in to the addons directory
- Restarted openhab
I have also tried with a .kar file instead of a .jar file, and get the same stack trace, but with more logs from karaf.
I have a dependency on openhab-runtime-base:
<feature name="openhab-binding-airgradient" description="AirGradient Binding" version="${project.version}">
<feature>openhab-runtime-base</feature>
<feature>openhab-transport-upnp</feature>
Is there something more I need to get AbstractThingHandlerDiscoveryService into the classloader?
(Before adding discovery, the new binding worked.)
