Node advancer: Retries exceeded at DYNAMIC_VALUES
Happens every time I startup, running latest 1.9 zwave binding.
2016-06-02 17:43:00 INFO  o.o.b.z.i.ZWaveActiveBinding[:337]- Update config, port = /dev/ttyACM0
2016-06-02 17:43:00 INFO  o.o.b.z.i.ZWaveActiveBinding[:342]- Update config, healtime = 2
2016-06-02 17:43:00 INFO  o.o.b.z.i.p.ZWaveController[:152]- Starting Z-Wave controller
2016-06-02 17:43:00 INFO  o.o.b.z.i.p.ZWaveController[:160]- Z-Wave timeout is set to 5000ms. Soft reset is false.
2016-06-02 17:43:00 INFO  o.o.b.z.i.p.ZWaveController[:326]- Connecting to serial port /dev/ttyACM0
2016-06-02 17:43:00 INFO  o.o.b.z.i.p.ZWaveController[:347]- Serial port is initialized
2016-06-02 17:43:03 INFO  o.o.b.z.i.p.s.SerialApiGetInitDataMessageClass[:60]- NODE 1: Node found
2016-06-02 17:43:03 INFO  o.o.b.z.i.p.s.SerialApiGetInitDataMessageClass[:60]- NODE 2: Node found
2016-06-02 17:43:03 INFO  o.o.b.z.i.p.s.SerialApiGetInitDataMessageClass[:68]- ZWave Controller using Controller API
2016-06-02 17:43:03 INFO  o.o.b.z.i.p.s.SerialApiGetInitDataMessageClass[:70]- ZWave Controller is Primary Controller
2016-06-02 17:43:03 INFO  o.o.b.z.i.p.s.SerialApiGetInitDataMessageClass[:72]- ------------Number of Nodes Found Registered to ZWave Controller------------
2016-06-02 17:43:03 INFO  o.o.b.z.i.p.s.SerialApiGetInitDataMessageClass[:73]- # Nodes = 2
2016-06-02 17:43:03 INFO  o.o.b.z.i.p.s.SerialApiGetInitDataMessageClass[:74]- ----------------------------------------------------------------------------
2016-06-02 17:43:06 ERROR o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:314]- NODE 2: Node advancer: Retries exceeded at DYNAMIC_VALUES
Item config.
Number Office_Tstat_HeatSetPoint                "Office Heat Setpoint [%.1f F]"                            <thermostat>    (Tstat11)                   {zwave="2:command=thermostat_setpoint,setpoint_type=1,setpoint_scale=1,refresh_interval=20" }
Number Office_Tstat_CoolSetPoint                "Office Cool Setpoint [%.1f F]"                            <thermostat>    (Tstat11)                   {zwave="2:command=thermostat_setpoint,setpoint_type=2,setpoint_scale=1,refresh_interval=20" }
Number  Office_Tstat_Temperature                "Office Temperature [%.1f °F]"             <temperature>   (Tstat11_Chart, Temperature)                {zwave="2:1:command=sensor_multilevel,sensor_type=1,refresh_interval=60"}
Number  Office_Tstat_Humidity                   "Office Humidity [%.1f %%]"                <humidity>      (Tstat11_Chart, Humidity)                {zwave="2:2:command=sensor_multilevel,sensor_type=5,refresh_interval=60"}
Number  Office_Tstat_ModeState                  "Office Mode [MAP(thermostatMode.map):%s]"            <climate>       (Tstat11)                   {zwave="2:command=thermostat_mode,refresh_interval=60"}
Number Office_Tstat_Fan_Mode                    "Office Fan Mode [MAP(thermostatFanMode.map):%s]"                     (Tstat11)                   {zwave="2:command=thermostat_fan_mode"}
Number  Office_Tstat_OpMode             "Office Operation State [MAP(thermostatOpState.map):%s]"              (Tstat11)                   {zwave="2:command=thermostat_operating_state,refresh_interval=60"}
Number Office_Tstat_Fan_State                   "Office Fan State [MAP(thermostatFanState.map):%s]"                   (Tstat11)                   {zwave="2:command=thermostat_fan_state"}
Number  Office_Tstat_Battery                    "Office Thermostat battery [%d %%]"                   <battery>       (Tstat11, Battery)           {zwave="2:command=BATTERY,refresh_interval=300"}
The logs really mean very little - you need to use the debug log to debug issues. Have a read of the following thread to work out how to work this through -:
Thanks, I noticed that the CLOCK command class is not supported, does that mean that all my thermostats will not have the time set? Also, last question, I started adding devices and I all of a sudden device 18 showed up in habmin. I thought it odd going from 1, 2, 3, and then 18. The node 18 device says UNKNOWN for everything, is there a way to delete it?
Yes.
In HABmin there should be an option to delete a node. I think it should show up in the toolbar if the device is marked as FAILED by the controller (I might be wrong though as it’s been a while since I used HABmin 1).
You willing to add CLOCK command set for a price?
I will try and take a look over the few days and if it’s working ok you can always PayPal me a few beer tokens :wink:.
No problem, can you send me your paypal?
