Node-Red installation through Openhabian-config fails
Does anyone else experience (or know of an issue) when installing Node-red through Openhabian-config? I am not in front of the PC at the moment, but it says “There was en error or interruption during the execution of 20 Optional Components”.
Afterwards, Node-red is installed, and I can start it through command line, but I am worried that there are options/customisations that are missing. I can for example not find it in the side panel from the OpenHAB interface.
I am running the Openhabian image downloaded from Raspberry Pi imager tool yesterday (09/11/2024), for my RPI 3B+. Not sure of the actual version of Openhabian, but I the OpenHAB version is 4.2.2.
I did let the Openhabian-config check and download updates prior to the installation.
Thanks in advance.
A vague question, description of an error will only get a vague answer - which will not help.
Follow the debug guide which provides detailed debug information; post that and based on that a detailed analysis can be done which will result in a detailed answer.
Reading your post like I may have an error; I don’t know if everything is ok or not it works but there could be something which I am not aware of could someone please help. So my answer is : I don’t know if I can help but I want to help. Does this help ?
Yes, that does help. I initially thought it was something I did wrong, but after a reinstall I figured this might be a known error that my skills could not help me find on Github (has happened before), but it does not seem like it. Apologies for the vaguely fomulated question, I shall try to find the debug information and post back when time permits.
So, today I was about to reinstall node-red, but as i was opening the openhabian-config there was an update. Enabling this update must have done something, as the node-red install worked perfectly afterwards. Thank you for your patience.
