Node-Red - Not updating item status
Hello guys I am currently trying to get bluelinky (node-red-contrib-bluelinky (node) - Node-RED) working with node-red and have it report status updates to openhab via the node red openhab rest api node-red-contrib-openhab2 (node) - Node-RED
This my current flow:
        "id": "f6f2187d.f17ca8",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": ""
        "id": "7151f9b3.64a868",
        "type": "car-status",
        "z": "f6f2187d.f17ca8",
        "name": "Get status",
        "dorefresh": true,
        "parsed": false,
        "bluelinky": "e0bc8bf7.f937a8",
        "x": 490,
        "y": 180,
        "wires": [
                "8c0e1278.48eeb"
        "id": "8c0e1278.48eeb",
        "type": "change",
        "name": "doorLock",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload.status.doorLock",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 680,
        "y": 180,
        "wires": [
                "5e5c84cd.fa00bc"
        "id": "73245381.663b7c",
        "type": "openhab2-in",
        "name": "",
        "controller": "da3bb014.482e5",
        "itemname": "GetBluelinkyStatus",
        "x": 150,
        "y": 180,
        "wires": [
                "8a29a69f.7baf48"
        "id": "5e5c84cd.fa00bc",
        "type": "openhab2-out",
        "name": "",
        "itemname": "BLDoorLockStatus",
        "topic": "ItemUpdate",
        "payload": "",
        "x": 910,
        "y": 180,
        "wires": [
        "id": "8a29a69f.7baf48",
        "type": "switch",
        "name": "",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "ON",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 330,
        "y": 180,
        "wires": [
                "7151f9b3.64a868"
        "id": "e0bc8bf7.f937a8",
        "type": "bluelinky",
        "username": "XXXXXXXXXXXXXX",
        "password": "XXXXXXXXXXXXXX",
        "region": "EU",
        "pin": "XXXXXXXXXXXXXX",
        "vin": "XXXXXXXXXXXXXX"
        "id": "da3bb014.482e5",
        "type": "openhab2-controller",
        "name": "Openhab",
        "protocol": "http",
        "host": "localhost",
        "port": "8080",
        "path": "",
        "username": "",
        "password": ""
Is this the correct way to send data to an item ?
If you are using OH 3 with NR you have to configure a token for the username to communicate with OH items; if you are using OH2.x then it should work.
