Hi all,
i find out a way to connect the Hue Sensors via Node-RED with openHAB with the Flows node-red-contrib-huemagic and node-red-contrib-openhab2 from the Node-RED library:
To get the Luminance there was a Switch that get the Values (Example:lightLevel) from the Hue-Sensor:
This Node was linked to an openHAB-Output-Node:
To get the Motion-Values there is function to convert the Values “true” or “false” to “ON” and “OFF”:
switch (msg.payload)
case false:
msg.payload = "OFF";
break;
case true:
msg.payload = "ON";
break;
default:
break;
return msg;
Regards
Heiko
