NodeMCU with several sensors integrating into OpenHab2 with MQTT?
I was planning to use a NodeMCU v2 (ESP8266) (with usb charger) and add these sensors: The Ultimate Raspberry Pi & Maker Store … ure-sensor
They have a digital output. I wanted to connect 5 of these sensors to different GPIOs of one NodeMCU.
Then I wanted to integrate the NodeMCU with the sensors into OpenHAB2. I did read that I need to do that with MQTT.
Can anybody confirm if it is possbible to use several sensors on one NodeMCU with ESPEasy and integrate it with MQTT in OpenHab2? I just need digital output of the sensors.
Or is there even a better way?
Getting the mqtt into openhab is no problem, the other half of your questions is better asked at the espeasy project. Have not tried that project as I like to program the devices myself which if you do that then multiple sensors are possible. If you need a working mqtt set of rules to copy find my milight thread in the solutions area of this forum.
I’ve used NodeMCU with 4 sensors (RF proximity, humidity, temp and voltage) and MQTT for sending sensor data to a Mosquitto broker running on Ubuntu 17.10 server. It’s quite easy to get it all working. I used this link as a starting point and developed from there. Alas, I cannot share the code as I do not have the intellectual property rights (commercial project), but I think you are dead on with respect to the technologies you’ve selected.
Although, I did not connect anything to OpenHab in this project, that should not be any problem.
My project https://www.thingiverse.com/thing:2539897 is a NodeMCU based multi-sensor with MQTT. I developed the code for it (GitHub - bkpsu/NodeMCU-Home-Automation-Sensor: Readme/Diagram for the "Kube" NodeMCU/DHT22 based MQTT temp/humidity home automation multi-sensor with local OLED display)) which allows configuration for different scenarios, including using the built-in DHT22 temp/humidity sensor, displaying information on the built-in OLED screen (for local info), etc…I also have an external input port, which I’ve used for connecting an HC-SR501 motion sensor (though it could be used for any 3-wire sensor or servo connection).
I also designed a PCB and case (as shown on the Thingiverse link), to make it all look a bit more put together.
If you want todo it the easy way, i mean no programming stuff, than use this software
on an NodeMCU or similar. Just flash, setup your MQTT settings and your sensors in the web Console and your gone
Is there a difference between Sonoff-Tasmota and ESPEasy concerning what I want to do?
If you want to do more complex stuff you also might wan’t to look into GitHub - homieiot/homie-esp8266: 💡 ESP8266 framework for Homie, a lightweight MQTT convention for the IoT. I use that for a bunch of simple temp & humidity sensors, works very smooth.
I did choose ESPEasy for using it with MQTT in Openhab2.
Another question I have now, is how to set up a graph for documenting and visualising temperature?
