I just bought a Xiaomi Aqara vibration sensor and zigbee binding successfully discovered it.
The binding created a thing with a single switch channel and I expect that it was switched to ON shaking the sensor. Unfortunately it isn’t.
This is the log when I move the sensor
2020-05-16 10:06:57.407 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0101, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=60], lastHopLqi=255, lastHopRssi=-46, sender=BB85, bindingIndex=255, addressIndex=255, messageContents=18 08 0A 55 00 21 01 00]
2020-05-16 10:06:57.411 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=BB85/1, destinationAddress=0000/1, profile=0104, cluster=0101, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=60, rssi=-46, lqi=FF, payload=18 08 0A 55 00 21 01 00]
2020-05-16 10:06:57.415 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=8, commandId=10]
2020-05-16 10:06:57.418 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Door Lock: BB85/1 -> 0000/1, cluster=0101, TID=08, reports=[AttributeReport [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=85, attributeValue=1]]]
2020-05-16 10:06:57.422 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ReportAttributesCommand [Door Lock: BB85/1 -> 0000/1, cluster=0101, TID=08, reports=[AttributeReport [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=85, attributeValue=1]]]
2020-05-16 10:06:57.426 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - BB85/1: Unknown Server attribute in 85 cluster 257
This mean that the device isn’t zigbee standard? Can I solve in any way?
