I am struggling with the following. I have 3 filament LEDs in my lamp. They are flashed with Tashmota firmware and work fine. I setup MQTT and am able to control all parameters from Paper UI.
To control them properly, I have a MiLight controller which can send out MQTT messages via an ESP8266. For power and dimmer, it works fine, but I cannot get the BW/WW to work from my MiLight controller. The Milight controller is converted from 153-370 (min-max) to 0-100.
In Paper UI, I use MQTT: stat/woonkamer/kroonluchter/tasmotas/CT (Stat and commands) for my LEDS with a minimum of 153 and max 500 parameter.
My Milight controller sends: milight/states/0x44C8/rgb_cct/1{“state”:“ON”,“level”:50,“color_temp”:344,“bulb_mode”:“white”}
I’m using the color_temp variable.
In my rules, I tried the following configuration:
rule "Milight Colour 01" when Item MilightControl_01_Colour changed then { val ColourState01 = math::round(MilightControl_01_Colour.state as Number Filament_Kroonluchter_ColourD.sendCommand(ColourState01) } end
I also used this rule: val ColourState01 = Math((MilightControl_01_Colour.state as Number - 153) * 2.17)
I am a bit lost, because it will not pick up any changes. Someone a suggestion?
