I have a WTRFID Mini Keypad RFID/Z-Wave connected via HABmin.
I search for a long tiime on openhab forum the way to enter a USER CODE in the keypad. @chris
Please could you help me to find the field in HABmin?
Let me know for further information,
Thanks for your help
Louis
Platform information: Raspberry Pi 3 Model B Plus Rev 1.3 with Razberry Zwave.me board
Hardware: CPUArchitecture/RAM/storage
OS: Openhabian / release Raspbian 10 / Linux 4.19.97-v7+
Java Runtime Environment: openJDK 1.8.0.22
openHAB version: 2.5.5-1
Issue of the topic: not able to find the field USER CODE in habmin for WTRFID Mini Keypad RFID/Z-Wave
I’m speculating a little here, but I see that the device is not securely included. Normally locks must be securely included into the network before certain classes can be used - eg you can’t unlock a door if the lock wasn’t securely included into the network.
I suspect that this may also be the case here - you can’t change PIN codes if the lock isn’t secured since it would be easy for someone to change the PIN and unlock your door.
I would suggest to exclude the device and ensure it is reset and included into the network securely.
Hi Chris,
Thanks for your answer, I have excluded the device and try to include it securely twice.
My concern is also when I include and exclude a device I can see a red led light on the Raz board switching on.
And after some inclusion/exclusion the red light doesn’t work anymore.
I restart openhab and communication between openhab and the board is OK now.
So the result is the same and I can read in the log it’s not secure, is it the reason why ?
I’m not really familiar with this device so I’m not really able to comment with any real authority on what’s happening. Are you able to provide a debug log showing the inclusion and initialisation?
You can find bellow, the log to include the WTRFID Mini Keypad RFID.
Let me know if you need more log.
Thanks WTRFID-node-6-inclusion.log (291.2 KB)
The log shows the binding is downloading the user codes, so I’m not sure why this isn’t showing up in the UI. I need to remind myself how this works - I thought it was as simple as the binding detecting this and providing these configuration options if it detects this feature in the device.
1 - The device is included and appears in the UI as “Z-Wave Node 006”
2 - A second trame of the device permit to identify the type Id
3 - With a F5/browser refresh, the name of the device appears in the UI like this "“Z-Wave Node 006 : WTRFID Mini Keypad RFID Combine”
4 - When I press the button ADD in the HABmin UI to import in the THING list, the first configuration loaded seems to be good, but no USER_CODE field
5 - After the WTRFID included, the device send a trame and the UI load another configuration and some field in the HABmin UI disappear.
6 - I add some items to check in Openhab and I can retreive some status : alarm_burglar and notification_access_control the rest do not return anything
This isn’t quite the way the configuration works. In any case, I’ve checked that my understanding is correct, so I don’t know why this isn’t being shown in the UI. Can you provide the XML for this device please?
Yep, I have 2 devices and both has the same behaviour and it’s not possible to find the USER_CODE field.
Let me know if you need more element, screenshot .
Thanks again for your time
