Pi 4, 4gb with Openhabian, latest updates installed
Hello, so basically the problem is as described in the title. Everything works fine, the items show up, I can use everything fine, but sometimes (sometimes more than once a day), Google home seems to be unable to access the items.
Now I checked the logs, but it seems to be allright. I get some disconnected and subsequent connected to cloud messages, but these seem to be expected, and the delay between them is on only about 5 mins. As my conenction can be a bit unstable, I am not supprised about this.
However, openhab does not seem to want to reconnect to the cloud services by itself. I can see the disconnect in the myopenhab dashboard, but there is no such indication in the openhab.log. There aren’t any additional log messages indicating errors, except this:
2021-05-07 16:18:00.008 [ERROR] [internal.events.ThreadedEventHandler] - Error on event handling.
at java.lang.String.contains(String.java:2036) ~[?:?]
at org.openhab.core.automation.internal.module.handler.ChannelEventTriggerHandler.apply(ChannelEventTriggerHandler.java:91) ~[?:?]
at org.openhab.core.internal.events.EventHandler.dispatchEvent(EventHandler.java:143) ~[bundleFile:?]
at org.openhab.core.internal.events.EventHandler.handleEvent(EventHandler.java:111) ~[bundleFile:?]
at org.openhab.core.internal.events.EventHandler.handleEvent(EventHandler.java:84) ~[bundleFile:?]
at org.openhab.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:67) [bundleFile:?]
I get a lot of this all over the day, and am uncertain what to think about it.
Is there anything else, except trying to get the system to reboot frequently?
Right now I have the system set to reboot at 3 am, but this does not seem like a good solution to me. Especially by now, when the failures happen more frequently.
Greatfull for any help!
