not possible to run openhab: set security manager called by org.eclipse.osgi.internal.framework.systembundleactivator
what am I supposed to do?
the version of openhab is :3.2.0MA
the version of java is: zulu17.30
I am trying to install it on windows 7
Lower Java runtime (zulu) to Java 11 and then try above. 11 is known to work.
I thought that was an issue with the version but I didn’t have time to try, I will try this evening and I’ll let you know, thanks buddy!
