Hello
I’ve configured my OpenHab with the KNX binding and it works as expected. I can read and interact with switches, temperatures, apertures, dates, times, blinds, etc … but I have a problem reading light levels form the KNX bus. The item configuration is at follows.
UID: knx:device:114022f816:e2fee499b7
label: Sensor Pasarela
thingTypeUID: knx:device
configuration:
pingInterval: 600
address: 1.1.22
readInterval: 0
fetch: true
bridgeUID: knx:ip:114022f816
channels:
- id: Luminosidad_Pasarela
channelTypeUID: knx:number
label: Luminosidad Pasarela
description: ""
configuration:
ga: 9.004:<1/7/16
On ETS I can see the values, I can force a red from ETS , but I don’t get the value on OpenHab.
I linked the channel to a item with the number configuration, but I only get NULL the item it’s defined as
type: Number:LuminousFlux
category: outdoorlight
groupNames:
- Estado_Ambiental
tags:
- Measurement
- Light
It`s there any way to get the 9.004 on OpenHab, KNX binding seems to have this implemented
Attached it’s a ETS capture where you can see the values.
