doe I have a possibility to get a trigger like above?
I need to catch an event when a switch changes state but did not receive any command.
Ist this possible?
Thanks a lot!
/KNEBB
Ist this possible?
Thanks a lot!
/KNEBB
No, a Trigger is suggested to start a rule. But you could use two rules, a proxy item and a timer:
Switch MyItem "Some Switch"
Switch MyProxy "only for rules"
and the rules:
var Timer tReset = null
rule "Set and reset Proxy"
Item MyItem received command
MyProxy.postUpdate(ON)
tReset?.cancel
tReset = createTimer(now.plusSeconds(2), [|
MyProxy.postUpdate(OFF)
rule "changed without command"
Item MyItem changed
if(MyProxy.state == ON) return; // cancel rule early
// item has changed, but last command was minimum 2 Seconds earlier
cool stuff!
I realized it by using a variable instead of a proxy item. Works like a charm!
Thanks for the idea!
/KNEBB
