Not Running as Daemon since upgrade to 2.2.0
Hey,
I have got one new issue… I updated to 2.2.0 today (before: 2.1.0) on Linux.
If I run it manually (./start.sh) everything works.
If I try to run it as service / daemon it seems to work, but the webpages tell me “ERR_CONNECTION_REFUSED”.
root@erbstadt-gaia:/lib/systemd/system# sudo systemctl status openhab2.service
● openhab2.service - The openHAB 2 Home Automation Bus Solution
   Loaded: loaded (/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
   Active: active (running) since So 2018-01-14 20:18:48 CET; 1min 11s ago
     Docs: http://docs.openhab.org
  Process: 3008 ExecStop=/bin/kill -SIGINT $MAINPID (code=exited, status=0/SUCCESS)
 Main PID: 3240 (karaf)
    Tasks: 202
   Memory: 715.2M
      CPU: 38.272s
   CGroup: /system.slice/openhab2.service
           ├─3240 /bin/sh /etc/openhab/runtime/bin/karaf server
           └─3389 /usr/bin/java -Dopenhab.home=/etc/openhab -Dopenhab.conf=/etc/openhab/conf -Dopenhab.runtime=/etc/openhab/runtime -Dopenhab.userdata=/etc/openhab/userdata -Dope
Jan 14 20:18:48 erbstadt-gaia systemd[1]: Started The openHAB 2 Home Automation Bus Solution.
Jan 14 20:18:48 erbstadt-gaia start.sh[3240]: Launching the openHAB runtime...
So it seems to work. If I have a look into the log files (./userdata/logs/) it also seems to be running… it receives data from the knx-bus and so on…
But the web-interface does not work anymore.
:frowning:
Any idea for me?
Look at the openhab.log around when it first starts up and see what networking interface it is binding to. If you have more than one and they are on different subnets it might default to only allowing connections from the other subnet. You should see something like Started dashboard at http://<ipaddress>:8080. Does <ip address> make sense?
Hey Rich,
you are right. Found the following in my log:
2018-01-17 17:15:23.779 [WARN ] [.jetty.internal.ServerControllerImpl] - SSL password and SSL keystore password must be set in order to enable SSL.
2018-01-17 17:15:23.783 [WARN ] [.jetty.internal.ServerControllerImpl] - SSL connector will not be started
2018-01-17 17:15:23.945 [ERROR] [.service.internal.HttpServiceStarted] - Could not start the servlet context for context path []
java.net.SocketException: Keine Berechtigung
	at sun.nio.ch.Net.bind0(Native Method) ~[?:?]
	at sun.nio.ch.Net.bind(Net.java:433) ~[?:?]
	at sun.nio.ch.Net.bind(Net.java:425) ~[?:?]
	at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:?]
	at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74) ~[?:?]
	at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:351) ~[?:?]
	at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:319) ~[?:?]
	at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80) ~[?:?]
	at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:235) ~[?:?]
	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) ~[?:?]
	at org.eclipse.jetty.server.Server.doStart(Server.java:401) ~[?:?]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl$1.start(JettyServerImpl.java:329) ~[?:?]
	at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:250) ~[?:?]
	at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerResources(HttpServiceStarted.java:299) ~[?:?]
	at org.ops4j.pax.web.service.internal.HttpServiceProxy.registerResources(HttpServiceProxy.java:72) ~[?:?]
	at org.openhab.io.rest.docs.internal.SwaggerService.activate(SwaggerService.java:40) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[?:?]
	at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[?:?]
	at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[?:?]
	at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) ~[?:?]
	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) ~[?:?]
	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:749) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) ~[?:?]
	at org.ops4j.pax.web.service.internal.Activator.updateController(Activator.java:352) ~[?:?]
	at org.ops4j.pax.web.service.internal.Activator.lambda$scheduleUpdateFactory$2(Activator.java:291) ~[?:?]
2018-01-17 17:15:24.023 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to de_DE, Location set to null, Time zone set to Europe/Berlin
But i dunno how to solve it… any further hint?
Patrick
That’s outside my experience. I’ve no suggestions.
Anyone else a hint for me? :-(..
