not successfully linked with Yeelight version 4 (Led Bulb 1S (Color), is my system having a problem or is it not yet supported by openhab/binding … please help me
{‘ip’: u’1.0.4.19’, ‘port’: 55443, ‘capabilities’: {u’hue’: u’0’, u’color_mode’: u’2’, u’name’: u’’, u’power’: u’on’, u’support’: u’get_prop set_default set_power toggle set_bright set_scene cron_add cron_get cron_del start_cf stop_cf set_ct_abx adjust_ct set_nameset_adjust adjust_bright adjust_color set_rgb set_hsv set_music’, u’rgb’: u’16711680’, u’fw_ver’: u’27’, u’bright’: u’100’, u’model’: u’color4’, u’ct’: u’6450’, u’id’: u’0x00000000117482f0’, u’sat’: u’100’}}
I get this info from the following method https://yeelight.readthedocs.io/en/latest/
