Hey it is not an OpenHAB problem, but perhaps someone happens to know a solution.
The NOUS A1T plug is connected to mqtt broker. Has anyone a solution to clear the measured values without resetting the device ?
Thank you.
Klaus-Dieter
Ist it running with Tasmota? In this case the command “EnergyReset” should do the job.
Solution found
