Hi, I have been successfully using Novelan Heatpump Binding for almost 2 years.
I have seen an update on GitHub 8 months ago with additional Heatpump output states, but i can’t get any readings of this output states.
Any ideas what is missing, I have OpenHab 2.4 and Heatpump firmware 1.81.
Can anyone get it to work or maybe reproduce the issue?
Is the problem that I have old binding version, but I reinstalled it with no resolution to the issue.
Otherwise binding works fine - updating other items that I listed below problematic ones.
These items don’t get any value - they stay NULL
Switch HeatPump_BUP_SanVoda "Ventil San.Voda output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_bup" }
Switch HeatPump_HUP_Radiatrji "Črpalka Radiatorji output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_hup" }
Switch HeatPump_VBO_VentTC "Ventilator TČ output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_vbo" }
Switch HeatPump_VD1_Kompresor "Kompresor TČ output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_vd1" }
Switch HeatPump_ZIP_pump "ZIP pump output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_zip" }
Switch HeatPump_ZUP_ObtCrp "TČ Obtocna Crpalka output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_zup" }
Switch HeatPump_ZW1_Grelec "Grelec TČ output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_zw1" }
Switch HeatPump_ZW2_sst "ZWE2 SST output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_zw2sst" }
Switch HeatPump_VDH "Heating output[%s]" <switch> (HeatpumpController_Outputs) { novelanheatpump="output_vdh" }
Number HeatPump_OFF_reason "Vzrok Izklopa [%s]" (HeatpumpController_Outputs) { novelanheatpump="switchoff_reason_0" }
Number HeatPump_lastError_code "Koda Zadnje Napake[%s]" (HeatpumpController_Outputs) { novelanheatpump="switchoff_code_0" }
Normally working items:
Group Heatpump (Ogrevanje)
Group HeatpumpController_Outputs (Ogrevanje)
Number HeatPump_Temperature_1 "W�rmepumpe Au�entemperatur [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_outside" }
Number HeatPump_Temperature_2 "R�cklauf [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_return" }
Number HeatPump_Temperature_3 "R�cklauf Soll [%.1f *C]" <temperature> (Heatpump) [ "CurrentTemperature" ] { novelanheatpump="temperature_reference_return" }
Number HeatPump_Temperature_4 "Vorlauf [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_supplay" }
Number HeatPump_Temperature_5 "Brauchwasser Soll [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_servicewater_reference" }
Number HeatPump_Temperature_6 "Brauchwasser Ist [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_servicewater" }
Number HeatPump_Temperature_7 "Solarkollektor [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_solar_collector" }
Number HeatPump_Temperature_8 "Solarspeicher [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_solar_storage" }
String HeatPump_State "Status [%s]" <temperature> (Heatpump) { novelanheatpump="state" }
Number HeatPump_Retrun_External "R�cklauf Extern [%.1f *C]" <temperature> (Heatpump) [ "CurrentTemperature" ] { novelanheatpump="temperature_out_external" } // return external
Number HeatPump_Hot_Gas "Temperatur Heissgas [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_hot_gas" } // return hot gas
Number HeatPump_Outside_Avg "mittlere Aussentemperatur [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_outside_avg" }
Number HeatPump_Probe_in "Sondentemperatur Eingang [%.1f *C]" <temperature> (Heatpump) [ "CurrentTemperature" ] { novelanheatpump="temperature_probe_in" }
Number HeatPump_Probe_out "Sondentemperatur Ausgang [%.1f *C]" <temperature> (Heatpump) [ "CurrentTemperature" ] { novelanheatpump="temperature_probe_out" }
Number HeatPump_Mk1 "Vorlauftemperatur MK1 IST [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_mk1" }
Number HeatPump_Mk1_Reference "Vorlauftemperatur MK1 SOLL [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_mk1_reference" }
Number HeatPump_Mk2 "Vorlauftemperatur MK2 IST [%.1f �C]" <temperature> (Heatpump) { novelanheatpump="temperature_mk2" }
Number HeatPump_Mk2_Reference "Vorlauftemperatur MK2 SOLL [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_mk2_reference" }
Number HeatPump_External_Source "Temperatur externe Energiequelle [%.1f *C]" <temperature> (Heatpump) { novelanheatpump="temperature_external_source" }
String HeatPump_Hours_Compressor1 "Betriebsstunden Verdichter1 [%s]" <clock> (Heatpump) { novelanheatpump="hours_compressor1" }
Number HeatPump_Starts_Compressor1 "Verdichter 1 [%.0f]" <clock> (Heatpump) { novelanheatpump="starts_compressor1" }
String HeatPump_Hours_Compressor2 "Betriebsstunden Verdichter2 [%s]" <clock> (Heatpump) { novelanheatpump="hours_compressor2" }
Number HeatPump_Starts_Compressor2 "Verdichter 2 [%.1f]" <clock> (Heatpump) { novelanheatpump="starts_compressor2" }
String HeatPump_Hours_Zwe1 "Betriebsstunden ZWE1 [%s]" <clock> (Heatpump) { novelanheatpump="hours_zwe1" }
String HeatPump_Hours_Zwe2 "Betriebsstunden ZWE2 [%s]" <clock> (Heatpump) { novelanheatpump="hours_zwe2" }
String HeatPump_Hours_Zwe3 "Betriebsstunden ZWE3 [%s]" <clock> (Heatpump) { novelanheatpump="hours_zwe3" }
String HeatPump_Hours_Heatpump "Betriebsstunden [%s]" <clock> (Heatpump) { novelanheatpump="hours_heatpump" }
String HeatPump_Hours_Heating "Betriebsstunden Heizung [%s]" <clock> (Heatpump) { novelanheatpump="hours_heating" }
String HeatPump_Hours_Warmwater "Betriebsstunden Brauchwasser [%s]" <clock> (Heatpump) { novelanheatpump="hours_warmwater" }
String HeatPump_Hours_Cooling "Betriebsstunden Kuehlung [%s]" <clock> (Heatpump) { novelanheatpump="hours_cooling" }
Number HeatPump_Thermalenergy_Heating "Waermemenge Heizung [%.1f KWh]" <energy> (Heatpump) { novelanheatpump="thermalenergy_heating" }
Number HeatPump_Thermalenergy_Warmwater "Waermemenge Brauchwasser [%.1f KWh]" <energy> (Heatpump) { novelanheatpump="thermalenergy_warmwater" }
Number HeatPump_Thermalenergy_Pool "Waermemenge Schwimmbad [%.1f KWh]" <energy> (Heatpump) { novelanheatpump="thermalenergy_pool" }
Number HeatPump_Thermalenergy_Total "Waermemenge gesamt seit Reset [%.1f KWh]" <energy> (Heatpump) { novelanheatpump="thermalenergy_total" }
Number HeatPump_Massflow "Massentrom [%.1f L/h]" <energy> (Heatpump) { novelanheatpump="massflow" }
String HeatPump_State_Ext "Status [%s]" <temperature> (Heatpump) { novelanheatpump="extended_state" }
Number HeatPump_heating_operation_mode "Heizung Betriebsart [%.0f]" (Heatpump) { novelanheatpump="heating_operation_mode" }
Number HeatPump_heating_temperature "Heizung Temperatur [%.1f]" (Heatpump) { novelanheatpump="heating_temperature" }
Number HeatPump_warmwater_operation_mode "Warmwasser Betriebsart [%.0f]" (Heatpump) { novelanheatpump="warmwater_operation_mode" }
Number HeatPump_warmwater_temperature "Warmwasser Temperatur [%.1f]" (Heatpump) { novelanheatpump="warmwater_temperature" }
Number HeatPump_Cool_BA "Betriebsart" (Heatpump) { novelanheatpump="cooling_operation_mode" }
Number HeatPump_Cooling_Release "Freigabe [%.1f *C]" (Heatpump) { novelanheatpump="cooling_release_temperature" }
Number HeatPump_Cooling_Inlet "Vorlauf Soll [%.1f *C]" (Heatpump) { novelanheatpump="cooling_inlet_temperature" }
Number HeatPump_Cooling_Start "AT �berschreitung[%.1f hrs]" (Heatpump) { novelanheatpump="cooling_start_hours" }
Number HeatPump_Cooling_Stop "AT Unterschreitung[%.1f hrs]" (Heatpump) { novelanheatpump="cooling_stop_hours" }
Thanks in advance
Matej
