now.minusMinutes(5) string issues
I am trying to get the avg GPM of my water meter, this worked with db4o, but changing to MySQL now breaks it:
rule "Water Rate"
  Time cron "0/5 * * * * ?"
  var ro_meter = RO_Water_Meter.deltaSince(now.minusMinutes(5), "mysql")
  if (ro_meter !== null) {
    RO_Water_Meter_GPM.postUpdate(ro_meter)
    logInfo("Water Meter", ro_meter)
  } else {
    RO_Water_Meter_GPM.postUpdate(0)
    logInfo("Water Meter", "null")
If I add .toString after my var such as:
var ro_meter = RO_Water_Meter.deltaSince(now.minusMinutes(5), "mysql").toString
It works, but I now can’t do the math I need (divide by 5).
Try something like this:
var ro_meter = RO_Water_Meter.deltaSince(now.minusMinutes(5), "mysql") as Number
Thanks, I did try that and got:
2021-13-06 05:13:10.010 [ERROR] [org.eclipse.smarthome.model.rule.runtime.internal.engine.ExecuteRuleJob ] - Error during the execution of rule 'Water Rate': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.LogAction.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null
However, I see from my MySQL log that it is not null:
06-Jan-2021 17:14:03.889 [DEBUG] [persistence.mysql.internal.MysqlPersistenceService] - mySQL: query: INSERT INTO Item6 (TIME, VALUE) VALUES(?,?) ON DUPLICATE KEY UPDATE VALUE=?;
06-Jan-2021 17:14:05.002 [DEBUG] [persistence.mysql.internal.MysqlPersistenceService] - mySQL query: item is RO_Water_Meter
06-Jan-2021 17:14:05.002 [DEBUG] [persistence.mysql.internal.MysqlPersistenceService] - mySQL: query:SELECT Time, Value FROM Item11 WHERE TIME<'2021-01-06 17:09:05' ORDER BY Time DESC LIMIT 0,1
06-Jan-2021 17:14:05.004 [DEBUG] [persistence.mysql.internal.MysqlPersistenceService] - mySQL: query returned 1 rows in 2ms
Try to check the individual steps with some logInfos:
logInfo("0", RO_Water_Meter.state)
logInfo("0.5", RO_Water_Meter.state.toString)
logInfo("1", RO_Water_Meter.deltaSince(now.minusMinutes(5), "mysql"))
logInfo("2", RO_Water_Meter.deltaSince(now.minusMinutes(5), "mysql").toString)
logInfo("3", RO_Water_Meter.deltaSince(now.minusMinutes(5), "mysql").toString as Number)
logInfo("4", RO_Water_Meter.deltaSince(now.minusMinutes(5), "mysql") as Number)
This will help to see what the status is and where exactly the problem appears.
The basic logInfo(X,Y) requires two strings. It’s not smart enough to deal with a non-string.
This will blow up- it’s a number.
This should work(except that the rule has already blown upon the previous line)
This does indeed work, but the problem I have is its a String and not a number so I can’t / by 5 like I need to.
Well, yes. For the logInfo() you want it as a string, to go in a message. If you want to do maths, yep you need a number. It’s up to you how you treat it on each occasion.
var myresult = RO_Water_Meter.deltaSince(now.minusMinutes(5), "mysql") as Number
// variable is a number
logInfo("result1", myresult.toString)
// we get the string version for our text message
// but the variable is still a number
var otherresult  = myresult / 5
// so we can do maths on that
logInfo("result2", otherresult.toString)
