NTP Binding - Formatting DateTime
I’m using openHAB 2.4 and looking at the NTP binding documentation here:
My things and items are defined per the documentation and listed below.
ntp.things
ntp:ntp:demo  [ hostname="us.pool.ntp.org", refreshInterval=60, refreshNtp=30 ]
ntp.items
DateTime Date  "Date [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]"  { channel="ntp:ntp:demo:dateTime" }
Am I missing something or should the Java documentation for formatting link point to:
Right now it doesn’t seem appropriate as it it points following which doesn’t seem to work for me.
Regards,
Burzin
That link results in a 404 error.
The second one (SimpleDateFormat (Java Platform SE 6)) is correct.
Oops poor copy and paste.
The above should work. My point is this the following table doesn’t produce usable results-- at least for me. Before updating the wiki, I’d like a sanity check. Perhaps my installation is wack somehow.
Regard,s
Burzin
You’ll need to define what you mean by “doesn’t work”. Maybe include the actual result that you’re thinking is wrong…
I want my sitemap to display the date and time like this:
This configuration gets me there
default.sitemap
sitemap default label="My Home" {
    Frame label="Current Date and Time" {
        Text item=Date
ntp.things
ntp.items
DateTime Date   "[%1$tA, %1$tB %1$td, %1$tY — %1$tl:%1$tM %1$tp]"  { channel="ntp:ntp:demo:dateTime" }
However, if I follow [SimpleDateFormat (Java Platform SE 6),
ntp.items looks like this:
DateTime Date   "[%1$tE, %1$tM %1$td, %1$ty — %1$th:%1$tm %1$ta]"  { channel="ntp:ntp:demo:dateTime" }
Translated that should equate to:
`E` Day in week [Text] - Example `Saturday` ;  `Sat`
`M` Month in year [Month] - Example `January` ;  `Jan` ;  `01`
`d` Day in month [Number] - Example `5`
`y` Year [Year] - Example '2019` ;  `19`
`h` Hour in am/pm (1-12) [Number]- Example '8`
`m` Minute in hour [Number] - Example `05`
`a` Am/pm marker [Text] - Example  `PM`
Instead of the desired output, I get this:
Regards,
Burzin
You’re right, that’s a defect in the README. The original OH1 README correctly points to the Formatter class instead of the SimpleDateFormat class.
I created an update request at: Update README.md by burzin-sumariwalla · Pull Request #6807 · eclipse-archived/smarthome · GitHub
Regards,
Burzin
