Hello there,
Currently I’m still running openhab 1, so I thought it might be time to migrate to the latest version.
However I’m running into problems getting the NTP time on the KNX bus.
Since there doesn’t seem to be a straightforward solution, i’ve resorted to this forum. I found some hints in Sending NTP time to KNX in OpenHAB3?
But the solution doesn’t work for me.
I’ve created a knx.things file pasting the code:
UID: knx:device:KNXDateTime
label: KNX DateTime Wrapper
thingTypeUID: knx:device
configuration:
pingInterval: 600
readInterval: 0
fetch: false
bridgeUID: knx:ip:Weinzierl730
channels:
- id: time
channelTypeUID: knx:datetime-control
label: DateTime
description: null
configuration:
ga: 10.001:6/0/1
Only to get errors like these:
Configuration model ‘knx.things’ has errors, therefore ignoring it: [3,1]: extraneous input ‘thingTypeUID’ expecting ‘:’
[7,3]: extraneous input ‘fetch’ expecting ‘:’
[10,1]: extraneous input ‘channels’ expecting ‘:’
[14,5]: extraneous input ‘description’ expecting ‘:’
[16,13]: missing EOF at ‘.’
As an openhab 3 newbie I could use some help here ![]()
