I’m considering to buy one as well. Any new experiences on battery lifetime? 8-10 weeks seems a bit short. Is there a way to connect it to a power source?
Also - does Nuki (lock and bridge) require constant internet access, or can I block it via Firewall, if I set up OpenHAB to control it?
This thread is quite old, but I just stumbled upon it, so I am gonna answer your questions. I recently bought the full setup (+Opener) and I am quite happy with it. Regarding your questions:
battery:
Life time (e.g. weeks / months)
We got ours in December and so far it looks good.
Open / Close Cycles per dnay
~10-15
Yes and no. There is Web Api which connects through web.nuki.io. However you can also directly control the lock via bluetooth or work with the bridge via the local Api. In fact, this is what the Nuki binding does.
Hard to tell - there is no percentage for battery status. It just reports, when the battery is getting low (which has not happened so far). Not sure how reliable the manufacturer info is, but based on the official help, the battery should be above 20%:
Nuki wird dir bei einem Batteriestand von ca. 20% per Nuki App und direkt am Smart Lock mitteilen, dass die Batterien bald leer sind.
Alright - thanks for the quick response.
My personal target would be to achieve 6 Months with a battery.
So I will ask you again in 4 months then (sorry)
some days ago my nuki wasn’t working properly anymore - the app showed “motor blocked” and the nuki was not able to open the door without a little manual help
however, the battery status was “OK” within the app
I could not figure out the obvious problem: the discounter-batteries I used were no good.
Now I switched to the recommended premium rechargeable batteries and… wow! The Nuki is faster and more responsive
I am posting this because of three things:
the original batteries seemed to work from December to somewhen in in March/ June (not entirely sure)
the replacement batteries “worked” since last week - however, they really worked just since July
I put in new and fully charged rechargable batteries today… so let’s see how long they’ll last
