i switched to the latest openhab 2.2 snapshot (from 2.12.2017) because i needed the actual zwave binding for a new device i bought.
Unfortunatly now Values from the Astro-Binding, which i use to decide if its dark or not, now delivers null values. I now checked different things but i didnt found a solution, so i start thie topic.
astro binding worked (on oh 2.1) before switching to 2.2.-snapshot with openhabian.config.
I also tried to delete all related items, things and even uninstalled the astro binding and i reinstalled astro-binding from paperui. i discovered and added the things of astro-binding via habmin tool.
it is marked as online.
Please check if these times are really there. a my location i had the problem, that there is by definition no night. You could check all time for your location by using: http://suncalc.net/
Do you ever see anything from the Astro binding? For example, you should see Scheduled Astro event-jobs for thing astro:home when OH starts (or if you were using .things files when you touch the .things file).
You should also see these log statements a little after midnight when Astro calculates the times for the new day.
This was a problem with 2.1 but 2.2 fix it for all the users who reported problems. This is what is so puzzling.
Seem that there are addtional problems with a data type called ZoneDateTime…?
I provide the full stack at the end of this post
regards
Mathias
07:39:43.612 [ERROR] [home.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'astro:sun:home': java.lang.NoSuchMethodError: org.eclipse.smarthome.core.library.types.DateTimeType.<init>(Ljava/time/ZonedDateTime;)V
java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.library.types.DateTimeType.<init>(Ljava/time/ZonedDateTime;)V
at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:?]
at java.util.concurrent.FutureTask.get(FutureTask.java:206) ~[?:?]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:199) ~[?:?]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:88) ~[?:?]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:72) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManager.doInitializeHandler(ThingManager.java:639) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManager.initializeHandler(ThingManager.java:574) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerAndInitializeHandler(ThingManager.java:961) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManager.thingAdded(ThingManager.java:369) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:213) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:132) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:136) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:56) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:74) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:78) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.lambda$21(GenericThingProvider.java:903) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.createThingsFromModelForThingHandlerFactory(GenericThingProvider.java:906) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.lambda$3(GenericThingProvider.java:299) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) [?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.createThingsFromModel(GenericThingProvider.java:301) [151:org.eclipse.smarthome.model.thing:0.9.0.201711242229]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.modelChanged(GenericThingProvider.java:715) [151:org.eclipse.smarthome.model.thing:0.9.0.201711242229]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:314) [134:org.eclipse.smarthome.model.core:0.9.0.201711242229]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:127) [134:org.eclipse.smarthome.model.core:0.9.0.201711242229]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:247) [134:org.eclipse.smarthome.model.core:0.9.0.201711242229]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processIgnoredFiles(FolderObserver.java:141) [134:org.eclipse.smarthome.model.core:0.9.0.201711242229]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.addModelParser(FolderObserver.java:88) [134:org.eclipse.smarthome.model.core:0.9.0.201711242229]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:658) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Caused by: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.library.types.DateTimeType.<init>(Ljava/time/ZonedDateTime;)V
at org.eclipse.smarthome.binding.astro.internal.util.PropertyUtils.getState(PropertyUtils.java:60) ~[?:?]
at org.eclipse.smarthome.binding.astro.handler.AstroThingHandler.publishChannelIfLinked(AstroThingHandler.java:156) ~[?:?]
at org.eclipse.smarthome.binding.astro.handler.AstroThingHandler.publishPlanet(AstroThingHandler.java:139) ~[?:?]
at org.eclipse.smarthome.binding.astro.handler.SunHandler.publishPositionalInfo(SunHandler.java:61) ~[?:?]
at org.eclipse.smarthome.binding.astro.handler.SunHandler.publishDailyInfo(SunHandler.java:53) ~[?:?]
at org.eclipse.smarthome.binding.astro.internal.job.DailyJobSun.run(DailyJobSun.java:50) ~[?:?]
at org.eclipse.smarthome.binding.astro.handler.AstroThingHandler.restartJobs(AstroThingHandler.java:183) ~[?:?]
at org.eclipse.smarthome.binding.astro.handler.AstroThingHandler.initialize(AstroThingHandler.java:108) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManager$6.call(ThingManager.java:642) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManager$6.call(ThingManager.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:186) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
at java.lang.Thread.run(Thread.java:748) ~[?:?]
In the future, it is a lot easier for us if you use copy and pasted in text with code fences rather than screen-shots unless there is something that cannot be represented with just the text.
When I’m reading on my phone, screenshots are completely illegible. Similarly, screenshots cannot be searched so other users who search on the same Exception would not come across this posting (you pasted it in at the end of your posting so that wouldn’t be the case here but you get the point).
It is weird the error just went away. I’m not aware of any changes that occurred recently that would have impacted this, but I am glad it is working for you now.
