Thanks for your first hints, @rlkoshak !
After removing the Think and setting a new Node ID in the printer plugin, I captured the log below. I have also put below the relevant MQTT messages, I could observe that switches & binary sensors have got True/False for the pl_on and pl_off tags. Tasmota devices have ON & OFF, respectivetely. Is this perhaps a inconsistency confusing OH?
Max
2021-02-16 21:14:23.141 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'mqtt:homeassistant_ef27c28b6ece4e10887113323bf30fcb2:Localhost:ef27c28b6ece4e10887113323bf30fcb2' to inbox.
2021-02-16 21:14:23.142 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'mqtt:homeassistant_ef27c28b6ece4e10887113323bf30fcb2:Localhost:ef27c28b6ece4e10887113323bf30fcb2' has been added.
2021-02-16 21:14:43.665 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'mqtt:homeassistant_ef27c28b6ece4e10887113323bf30fcb2:Localhost:ef27c28b6ece4e10887113323bf30fcb2' has been removed.
2021-02-16 21:14:43.673 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant_ef27c28b6ece4e10887113323bf30fcb2:Localhost:ef27c28b6ece4e10887113323bf30fcb2' changed from UNINITIALIZED to INITIALIZING
2021-02-16 21:14:43.693 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant_ef27c28b6ece4e10887113323bf30fcb2:Localhost:ef27c28b6ece4e10887113323bf30fcb2' changed from INITIALIZING to UNKNOWN
2021-02-16 21:14:43.753 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant_ef27c28b6ece4e10887113323bf30fcb2:Localhost:ef27c28b6ece4e10887113323bf30fcb2' changed from UNKNOWN to OFFLINE
2021-02-16 21:14:45.796 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command 'false' not supported by type 'OnOffValue': No enum constant org.openhab.core.library.types.OnOffType.false
2021-02-16 21:14:45.805 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.thingUpdated()' on 'org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler@bdc456': java.util.ConcurrentModificationException
java.util.ConcurrentModificationException: java.util.ConcurrentModificationException
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at java.util.concurrent.ForkJoinTask.getThrowableException(ForkJoinTask.java:600) ~[?:?]
at java.util.concurrent.ForkJoinTask.reportException(ForkJoinTask.java:678) ~[?:?]
at java.util.concurrent.ForkJoinTask.invoke(ForkJoinTask.java:737) ~[?:?]
at java.util.stream.ReduceOps$ReduceOp.evaluateParallel(ReduceOps.java:919) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:233) ~[?:?]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578) ~[?:?]
at org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler.stop(HomeAssistantThingHandler.java:217) ~[?:?]
at org.openhab.binding.mqtt.generic.AbstractMQTTThingHandler.dispose(AbstractMQTTThingHandler.java:253) ~[?:?]
at org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler.dispose(HomeAssistantThingHandler.java:175) ~[?:?]
at org.openhab.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:150) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor148.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Caused by: java.util.ConcurrentModificationException
at java.util.HashMap$ValueSpliterator.forEachRemaining(HashMap.java:1680) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
at java.util.stream.ReduceOps$ReduceTask.doLeaf(ReduceOps.java:952) ~[?:?]
at java.util.stream.ReduceOps$ReduceTask.doLeaf(ReduceOps.java:926) ~[?:?]
at java.util.stream.AbstractTask.compute(AbstractTask.java:327) ~[?:?]
at java.util.concurrent.CountedCompleter.exec(CountedCompleter.java:746) ~[?:?]
at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:290) ~[?:?]
at java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1020) ~[?:?]
at java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1656) ~[?:?]
at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1594) ~[?:?]
at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:183) ~[?:?]
2021-02-16 21:14:45.857 [WARN ] [.transport.mqtt.MqttBrokerConnection] - Failed subscribing to topic octoPrint/progress/printing
java.util.NoSuchElementException: null
at com.hivemq.client.rx.FlowableWithSingle$SingleFutureSubscriber.onComplete(FlowableWithSingle.java:385) [bundleFile:?]
at com.hivemq.client.internal.rx.operators.FlowableWithSingleCombine$SplitSubscriber.onComplete(FlowableWithSingleCombine.java:183) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableObserveOn$BaseObserveOnSubscriber.checkTerminated(FlowableObserveOn.java:199) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableObserveOn$ObserveOnConditionalSubscriber.runAsync(FlowableObserveOn.java:641) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableObserveOn$BaseObserveOnSubscriber.run(FlowableObserveOn.java:176) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:66) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2021-02-16 21:14:45.861 [WARN ] [al.handler.HomeAssistantThingHandler] - Failed to start component mqtt:homeassistant_ef27c28b6ece4e10887113323bf30fcb2:Localhost:ef27c28b6ece4e10887113323bf30fcb2:ef27c28b6ece4e10887113323bf30fcb2_5FPRINTING_5FF
java.util.concurrent.CompletionException: java.util.NoSuchElementException
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:331) ~[?:?]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:346) ~[?:?]
at java.util.concurrent.CompletableFuture$UniRun.tryFire(CompletableFuture.java:777) ~[?:?]
at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:506) [?:?]
at java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:2088) [?:?]
at org.openhab.core.io.transport.mqtt.MqttBrokerConnection.lambda$1(MqttBrokerConnection.java:513) [bundleFile:?]
at java.util.concurrent.CompletableFuture.uniWhenComplete(CompletableFuture.java:859) [?:?]
at java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(CompletableFuture.java:837) [?:?]
at com.hivemq.client.internal.mqtt.mqtt3.Mqtt3AsyncClientView.lambda$handleSubAck$0(Mqtt3AsyncClientView.java:64) [bundleFile:?]
Caused by: org.openhab.core.io.transport.mqtt.MqttException
... 22 more
Caused by: java.util.NoSuchElementException
... 12 more
2021-02-16 21:14:45.899 [WARN ] [.incoming.MqttIncomingPublishService] - No publish flow registered for MqttStatefulPublish{stateless=MqttPublish{topic=octoPrint/progress/printing, payload=94byte, qos=AT_MOST_ONCE, retain=true}, packetIdentifier=-1, dup=false, topicAlias=0, subscriptionIdentifiers=[]}.
MQTT messages
homeassistant/switch/ef27c28b6ece4e10887113323bf30fcb2_STOP/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Emergency Stop", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_STOP", "cmd_t": "~hassControl/stop", "stat_t": "~hassControl/stop", "pl_off": "False", "pl_on": "True", "val_tpl": "{{False}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:alert-octagon"}
homeassistant/switch/ef27c28b6ece4e10887113323bf30fcb2_CANCEL/config {"avty_t": "~hass/is_printing", "pl_avail": "True", "pl_not_avail": "False", "~": "octoPrint/", "name": "3D Printer Cancel Print", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_CANCEL", "cmd_t": "~hassControl/cancel", "stat_t": "~hassControl/cancel", "pl_off": "False", "pl_on": "True", "val_tpl": "{{False}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:cancel"}
homeassistant/switch/ef27c28b6ece4e10887113323bf30fcb2_PAUSE/config {"avty_t": "~hass/is_printing", "pl_avail": "True", "pl_not_avail": "False", "~": "octoPrint/", "name": "3D Printer Pause Print", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PAUSE", "cmd_t": "~hassControl/pause", "stat_t": "~hass/is_paused", "pl_off": "False", "pl_on": "True", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:pause"}
homeassistant/switch/ef27c28b6ece4e10887113323bf30fcb2_SHUTDOWN/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Shutdown System", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_SHUTDOWN", "cmd_t": "~hassControl/shutdown", "stat_t": "~hassControl/shutdown", "pl_off": "False", "pl_on": "True", "val_tpl": "{{False}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:power"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_EVENT/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Last Event", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_EVENT", "stat_t": "~event/+", "val_tpl": "{{value_json._event}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_PRINTING_S/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Print Status", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PRINTING_S", "stat_t": "~hass/printing", "json_attr_t": "~hass/printing", "json_attr_tpl": "{{value_json.state|tojson}}", "val_tpl": "{{value_json.state.text}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_PRINTING_P/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Print Progress", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PRINTING_P", "json_attr_t": "~hass/printing", "json_attr_tpl": "{{value_json.progress|tojson}}", "stat_t": "~progress/printing", "unit_of_meas": "%", "val_tpl": "{{value_json.progress|float|default(0,true)}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_PRINTING_F/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Print File", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PRINTING_F", "stat_t": "~progress/printing", "val_tpl": "{{value_json.path}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:file"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_PRINTING_T/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Print Time", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PRINTING_T", "stat_t": "~hass/printing", "val_tpl": "{{value_json.progress.printTimeFormatted}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:clock-start"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_PRINTING_E/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Print Time Left", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PRINTING_E", "stat_t": "~hass/printing", "val_tpl": "{{value_json.progress.printTimeLeftFormatted}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:clock-end"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_PRINTING_ETA/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Print Estimated Time", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PRINTING_ETA", "stat_t": "~hass/printing", "json_attr_t": "~hass/printing", "json_attr_tpl": "{{value_json.job|tojson}}", "val_tpl": "{{value_json.job.estimatedPrintTimeFormatted}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_PRINTING_Z/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Current Z", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PRINTING_Z", "stat_t": "~hass/printing", "unit_of_meas": "mm", "val_tpl": "{{value_json.currentZ|float}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:axis-z-arrow"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_SLICING_P/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Slicing Progress", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_SLICING_P", "stat_t": "~progress/slicing", "unit_of_meas": "%", "val_tpl": "{{value_json.progress|float|default(0,true)}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_SLICING_F/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Slicing File", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_SLICING_F", "stat_t": "~progress/slicing", "val_tpl": "{{value_json.source_path}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "ic": "mdi:file"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_TOOL0/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Tool 0 Temperature", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_TOOL0", "stat_t": "~temperature/tool0", "unit_of_meas": "\u00b0C", "val_tpl": "{{value_json.actual|float}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "dev_cla": "temperature", "ic": "mdi:printer-3d-nozzle"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_TOOL0_TARGET/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Tool 0 Target", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_TOOL0_TARGET", "stat_t": "~temperature/tool0", "unit_of_meas": "\u00b0C", "val_tpl": "{{value_json.target|float}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "dev_cla": "temperature", "ic": "mdi:printer-3d-nozzle"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_BED/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Bed Temperature", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_BED", "stat_t": "~temperature/bed", "unit_of_meas": "\u00b0C", "val_tpl": "{{value_json.actual|float}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "dev_cla": "temperature", "ic": "mdi:radiator"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_BED_TARGET/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Bed Target", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_BED_TARGET", "stat_t": "~temperature/bed", "unit_of_meas": "\u00b0C", "val_tpl": "{{value_json.target|float}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "dev_cla": "temperature", "ic": "mdi:radiator"}
homeassistant/sensor/ef27c28b6ece4e10887113323bf30fcb2_SOC/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer SoC Temperature", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_SOC", "stat_t": "~temperature/soc", "unit_of_meas": "\u00b0C", "val_tpl": "{{value_json.temperature|float|round(1)}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}, "dev_cla": "temperature", "ic": "mdi:radiator"}
homeassistant/binary_sensor/ef27c28b6ece4e10887113323bf30fcb2_CONNECTED/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Connected", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_CONNECTED", "stat_t": "~hass/Connected", "pl_on": "Connected", "pl_off": "Disconnected", "dev_cla": "connectivity", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}}
homeassistant/binary_sensor/ef27c28b6ece4e10887113323bf30fcb2_PRINTING/config {"avty_t": "~mqtt", "pl_avail": "connected", "pl_not_avail": "disconnected", "~": "octoPrint/", "name": "3D Printer Printing", "uniq_id": "ef27c28b6ece4e10887113323bf30fcb2_PRINTING", "stat_t": "~hass/printing", "pl_on": "True", "pl_off": "False", "val_tpl": "{{value_json.state.flags.printing}}", "device": {"ids": "ef27c28b6ece4e10887113323bf30fcb2", "name": "3D Printer", "mf": "Creality", "mdl": "Ender 3 Pro", "sw": "HomeAssistant Discovery for OctoPrint 3.2.1"}}
