Lock/unlock actions
Is there any plan to implement lock/unlock actions to the skill?
I want to say “Ok Google Unlock Frontdoor”
/mike
Lock/unlock actions
/mike
The same goes for open/close.
That would require Google to integrate that into their API, which currently is not the case.
Until then, you can use something like “Turn on front door lock”. With a proxy device called “front door lock” and the appropriate rules to forward the right commands to the door lock item.
How can Nuki have Okay Google, lock the door?
https://nuki.io/en/blog/new-nuki-smart-home-action-for-your-google-assistant/
/Mike
Is there any way that i can use my google home as a bridge to control device with my openhab?
For example, i have a device that is not supported by openhab but can be controlled by google home and i want to control it via a button in habpanel or add it in a rule. Is that possible?
thanks for you work by the way
Patrick
Yes. I will be publishing a how-to on that.
Hello, tried setting up a thermostat in home assistant. I can see the theremostat and open it in google home app, but it doesnt show the current temperature and i cant set the targettemperature or the mode. neigther can i see the current humidity.
Group GF_Hallway_Thermostat "Thermostaat gang" [ "Thermostat" ]
Number GF_Hallway_HeatingMode "Verwarmingsmode gang [%s]" (GF_Hallway_Thermostat) [ "homekit:HeatingCoolingMode" ]
Number GF_Hallway_Temp_Meas_BedroomDoor "Gemeten temperatuur gang [%.1f °C]" <temperature> (GF_Hallway_Temp_Meas, gTemp_Meas, ID125, GF_Hallway_Thermostat) [ "CurrentTemperature" ]
Number GF_Hallway_Temp_Target "Gewenste temperatuur gang [%.1f °C]" <temperature> (GF_Hallway, gTemp_Target, gHallway_Temp_Chart, GF_Hallway_Thermostat) ["TargetTemperature"]
Number GF_Hallway_Hum_BedroomDoor "Luchtvochtigheid gang [%.1f %%]" <humidity> (GF_Hallway_Hum, ID125, GF_Hallway_Thermostat) [ "CurrentHumidity" ]
Does anyone see something wrong with my items? I really cant semm to find a problem.
Lighting tags work great for me.
First trying the easy things: Add spaces between the brackets and the quotation marks:
[ "TargetTemperature" ]
Hello, thanks for the suggestion. I made shure i have spaces between the brackets and quotation marks for all the tags now but the problem persists
Also after you synced your devices? “Ok Google, sync my devices”, or looking at your Item labels “OK Google, synchroniseer mijn apparaten”.
If it still persists. I am not sure if having the humidity and heating mode in the same group messes up things, you might try removing them from the GF_Hallway_Thermostat group. (And again sync)
Hello! When is it planned to add support in Russia? Voice control does not work. https://assistant.google.com/services/a/uid/000000f5c61c627e?hl=en-US&source=web
Hi, yes i synced the devices (in English and in dutch )
Do you mean remove the current humidity, remove heatingmode or remove both from the thermostat group?
I removed only the humidity from the group, synced, but no change. The allso removed heatingmode from group, synced, but still no change.
I allso noticed the thermostat appeared in google home after adding only “current temperature” tag.
When using only “current temperature” the thermostat widget appears in google home, but no temperature is indicated.
Is it possible the thermostat tag is not propperly supported yet? Is there anyone else on this toppic that has the thermostat functioning properly? If so could you paste your item definitions pls?
Hmm out of idea’s then… My thermostat works fine, I have everything defined via Paper UI though, and added the tags through Karaf.
Ok, thanks for your time anyway. I have everything configured thru files, maybe thats the problem. Or maybe because only current temp and current humid are linked thru chanels to a thing.
I might try linking the others to a generic mqtt thing and see if that makes any difference. Otherwise maybe when i order my new eq3 thermostats in the future.
This is not a problem OpenHAB2, this is a Google problem. I think when the Google Assistant will be officially launched in Russia, then everything will work in Russian.
Are you shure this list is up to date? Because the google assistant on my phone works just fine in dutch and a dutch google home has been officialy launched in Holland. Granted i live in Belgium but we speak the same language.
Greets
How can Nuki have Okay Google, lock the door ?
https://nuki.io/en/blog/new-nuki-smart-home-action-for-your-google-assistant//Mike
You can create a routine in the google home app: when you say “unlock the door” google assistant have to send the command “turn on the door”
I have done it and it works!
But routines still only work in English, correct? Don’t think they are available yet in Dutch for example (my case)
Don’t know about Dutch, but in Italian are available.
If routines are not available in your language you could try with IFTTT, maybe it is available in Dutch, the only downside is a bit more lag
