unfortunately, the tab Home control appears only in the English language assistant. when reset to Russian it disappears.
Try opdate you APP from APKmirror. I run a danish langauge, and do have the Home controle. I do however update from APKmirror, because Google hasn´t realease Google Home for the danish market yet.
I’m using a fibaro dimmer2 and I’ve configuered the following two items:
Switch F1_Dimmer_Switch "Luce in taverna" <light> (gC) ["Lighting"] {channel="zwave:device:158ddb77754:node10:switch_dimmer1"}
Dimmer F1_Dimmer "Luminosità luce taverna [%d %%]" <light> (gC) ["Lighting"] {channel="zwave:device:158ddb77754:node10:switch_dimmer1"}
The problem is that if I put the two items on the same room named “taverna” and I Say “Turn on Taverna Light” the assistant found two switchable item on the room and dont’ work. If I remove the dimmer from the room instead I can switch on and off the light.
How can I control a switch and a dimmer on the same room ?
Regards
I think you only need the “Dimmer” item - you can remove the “switch” item.
It should still allow you to say “Turn on …” and control that device.
Hi there guys, i’m having problem with google assistant, today my devices wasn’t online, i have removed the service from Home App and while adding i receive an error msg o.O
Myopenhab cloud is working fine…
I have no clue
I’m having the exact same issue!
Everything was working fine, until on today’s google logs I got the following message:
com.google.homeautomation
Sorry I cound’t reach openHAB
Anyone else having similar issues
Runing openhabian 2.3 up to date and working until this morning
I have since unlinked and attempted to relink the account but am running into the following message from the google home app:
Couldn’t update the setting. Check your connection
I’m seconds away from grabbing my backup image and tossing it online to see if that’s the fix, but since kvgeta is having a similar issue, is it service based?
I have the same problem since today.
And I can’t sign in to OH cloud.
“Unknown user or incorrect password”
" Sorry I cound’t reach openHAB"
When relink in Google Home app…
" Couldn’t update the setting. Check your connection"
Exactly same problem since today!!!
Who should we be tagging to take a peek into what’s going on with the service?
Thanks Sam
Checking it now.
Myopenhab.org and the Google Assistant connection is working. Can you try it again, directly after it cant connect?
Have the same problem… I removed the connection and re-added it, only to be told it no longer works… Thanks google!
I just tried re-add the connection. I get an error, “cant etablish connection, check your connection”, in Google Home app.
Just tried again. And now it works… Weird!!
Same problem here, “cant etablish connection, check your connection”, in Google Home app.
And now it works again
Hi all,
We have hit the free tier limit.
I havent received the info, just saw that in the log files at Google.
The openHAB Google Assistant was and is working, it was Google blocking until payment tier was accepted. Strange move.
After certain amount of time or requests per month, Google switches to paid tier. Actually we have a loooot users, using this integration.
It should work fine now again. Have fun!
BR Mehmet
Thanks Mehmet!
Thank you very much!
I’ve always been impressed by your work with the project! Great Job!
