HEEELP HEEELP !! I already cleared the cache but it’s still the same
There’s not a lot of information here.
What is your MQTT broker?
How did you setup your bridge to the MQTT broker?
Are you sure your MQTT broker is running?
There will be more detail in your openhab.log
Has this ever worked, or are starting out new with MQTT ?
Looks like the embedded broker is struggling because a file it uses has been trashed. Maybe that’s down to a failing SD card if you have one, or an unexpected power failure.
because if you are starting out, the advice is not to use the embedded broker.
