I had previously installed OH manually, but was able to upgrade using apt-get the other day. It appears that after upgrading from 1.7 to 1.8.1, my installation directory is now /etc/openhab and /usr/share/openhab. I copied all of the relevant files (I think), and am able to access my sitemap, but I believe something is up with a couple bindings.
My Z-Wave binding appears to be working, but I am seeing some log messages that were not previously present. This is from openhab.log:
[WARN ] [i.internal.GenericItemProvider] - Attempted to register a second BindingConfigReader of type 'zwave'. The primaraly reader will remain active!
and this is from my z-wave log (logback is set to Error right now):
2016-02-07 10:43:53.817 [ERROR] [b.z.i.protocol.ZWaveController:467 ]- NODE 1: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.converters.ConversionException: No enum constant org.openhab.binding.zwave.internal.protocol.ZWaveDeviceClass.Generic.STATIC_CONTROLLER : No enum constant org.openhab.binding.zwave.internal.protocol.ZWaveDeviceClass.Generic.STATIC_CONTROLLER
---- Debugging information ----
message : No enum constant org.openhab.binding.zwave.internal.protocol.ZWaveDeviceClass.Generic.STATIC_CONTROLLER
cause-exception : java.lang.IllegalArgumentException
cause-message : No enum constant org.openhab.binding.zwave.internal.protocol.ZWaveDeviceClass.Generic.STATIC_CONTROLLER
class : org.openhab.binding.zwave.internal.protocol.ZWaveDeviceClass$Generic
required-type : org.openhab.binding.zwave.internal.protocol.ZWaveDeviceClass$Generic
converter-type : com.thoughtworks.xstream.converters.enums.EnumConverter
path : /node/deviceClass/genericDeviceClass
line number : 4
class[1] : org.openhab.binding.zwave.internal.protocol.ZWaveDeviceClass
converter-type[1] : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
class[2] : org.openhab.binding.zwave.internal.protocol.ZWaveNode
version : 1.4.6
My Nest binding also appears to have freaked out, but I am not 100% sure it was good prior to upgrade (it had been maybe a week or two since I opened my OH sitemap. Logback is set to Error right now as well.
Prior to upgrade:
2016-02-06 15:06:29.612 ERROR o.o.b.n.internal.NestBinding[:352]- Error updating data model: DataModelResponse[devices=<null>,structures=<null>]
After upgrade:
ERROR o.o.b.n.internal.NestBinding[:622]- Error retrieving access token: AccessTokenResponse[accessToken=<null>,expiresIn=<null>,error=oauth2_error,errorDescription=authorization code not found]'
Thank you for taking the time to read this!
