Bredmich
(Michael)
March 27, 2018, 11:32am
1
Hi there,
i´m currently trying to connect my openHAB 1.8.3 installation to myopenhab.org .
The goal is to connect oH and Alexa through myopenhab.org .
myopenhab.org always says my installation is Offline.
I already checked some of the threads here and none of the solutions helped.
Environment:
Raspberry Pi 3
Raspbian 8 Jessie
openHAB 1.8.3
I already checked the UUID and Secret twice and even deleted them and used the newly created.
openhab.cfg
security:option=EXTERNAL
security:netmask=192.168.2.0/24
Debug Log (with only myopenhab)
2018-03-27 12:21:17.034 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'myopenhab.persist'
2018-03-27 12:21:32.561 [DEBUG] [.m.i.MyOpenHABServiceActivator] - MyOpenHAB service has been started.
2018-03-27 12:21:32.568 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - setEventPublisher
2018-03-27 12:21:32.569 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - my.openHAB service activated
2018-03-27 12:21:32.571 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - config is null
2018-03-27 12:21:32.574 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - UUID file found at '/usr/share/openhab/webapps/static/uuid' with content '4def12f1-9c16-456f-acb7-8bbdcae45a43'
2018-03-27 12:21:32.575 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - Secret file already exists at '/usr/share/openhab/webapps/static/secret' with content 'jjF2geECnn9thyBpA6yX'
2018-03-27 12:21:32.576 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - UUID = 4def12f1-9c16-456f-acb7-8bbdcae45a43, secret = jjF2geECnn9thyBpA6yX
2018-03-27 12:21:32.583 [DEBUG] [.p.internal.PersistenceManager] - Initializing myopenhab persistence service.
2018-03-27 12:21:32.609 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - UUID file found at '/usr/share/openhab/webapps/static/uuid' with content '4def12f1-9c16-456f-acb7-8bbdcae45a43'
2018-03-27 12:21:32.613 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - Secret file already exists at '/usr/share/openhab/webapps/static/secret' with content 'jjF2geECnn9thyBpA6yX'
2018-03-27 12:21:32.616 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - Version file found at '/usr/share/openhab/webapps/static/version' with content '1.8.3'
2018-03-27 12:21:32.723 [DEBUG] [.myopenhab.internal.MyOHClient] - Manager.EVENT_TRANSPORT
2018-03-27 12:21:33.053 [DEBUG] [.myopenhab.internal.MyOHClient] - Transport.EVENT_REQUEST_HEADERS
2018-03-27 12:21:33.507 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - store(calAbfallTonne), state = Undefined
2018-03-27 12:21:33.509 [DEBUG] [.myopenhab.internal.MyOHClient] - No connection, Item update is not sent
2018-03-27 12:21:33.514 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - store(calAbfallDate), state = Undefined
2018-03-27 12:21:33.515 [DEBUG] [.myopenhab.internal.MyOHClient] - No connection, Item update is not sent
2018-03-27 12:21:36.676 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl] - store(Wohnzimmer), state = Undefined
2018-03-27 12:21:36.678 [DEBUG] [.myopenhab.internal.MyOHClient] - No connection, Item update is not sent
Any ideas how to get my oH intallation to speak with myopenhab.org ?
Cheers
Michael
opus
(Jürgen Baginski)
March 27, 2018, 11:57am
2
What Java -version do you have (should be above 1.8.0_104 I think) . This error is overcome by updating the Java version in most cases!
Bredmich
(Michael)
March 27, 2018, 12:11pm
3
pi@HER-MB-OpenHab:~ $ sudo apt-cache showpkg oracle-java8-jdk
Package: oracle-java8-jdk
Versions:
8u65 (/var/lib/apt/lists/archive.raspberrypi.org_debian_dists_jessie_main_binary-armhf_Packages) (/var/lib/dpkg/status)
Description Language:
File: /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_jessie_main_binary-armhf_Packages
MD5: 8fb8c32eba2d82fb7a74c04bb9c5cd11
Reverse Depends:
wolfram-engine,oracle-java8-jdk
greenfoot,oracle-java8-jdk
bluej,oracle-java8-jdk
Dependencies:
8u65 - libasound2 (2 1.0.16) libc6 (2 2.4) libgcc1 (2 1:4.4.0) libx11-6 (0 (null)) libxext6 (0 (null)) libxi6 (0 (null)) libxrender1 (0 (null)) libxtst6 (0 (null)) netbase (0 (null))
Provides:
8u65 - java8-sdk java8-runtime-headless java8-runtime java7-sdk java7-runtime-headless java7-runtime java6-sdk java6-runtime-headless java6-runtime java5-sdk java5-runtime-headless java5-runtime java2-sdk java2-runtime-headless java2-runtime java2-compiler java-virtual-machine java-sdk java-runtime-headless java-runtime java-compiler java-browser-plugin
Reverse Provides:
Bredmich
(Michael)
March 27, 2018, 1:30pm
5
Are you sure?
pi@HER-MB-OpenHab:/etc/openhab $ java -v
Unrecognized option: -v
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
Edit:
pi@HER-MB-OpenHab:/etc/openhab $ java -version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
How to only update the Java environment?
opus
(Jürgen Baginski)
March 27, 2018, 1:46pm
6
How about looking Here ?
Look under “Meeting requirements”.
Bredmich
(Michael)
March 27, 2018, 1:50pm
7
I´m using 1.8.3 and not 2
There´s nothing like “Meeting requirements” in your link
How do i only update the oracle java environment?
opus
(Jürgen Baginski)
March 27, 2018, 1:58pm
8
It is understood that you are (still) on 1.8.3, and please scroll down to see the bold printed "MeetIng requirements ". They talk about updating or installing java . I think 1.8.3 will run on the same java as 2.x( keeping fingers crossed) Else use the search function of the forum (that is what I did).
BTW: An Installation of OH2 using a openhabian image is pretty easy, don’t get left behind!
Bredmich
(Michael)
March 27, 2018, 2:06pm
9
Sorry but there´s no information about updating an existing java environment… or i´m not able to find it…
Just some suggestions for Zulu.
I don´t want to change my whole system, just updating the java to get myopenhab.org back running.
Meeting the Requirements: As a first step, please verify, that your system meets the prerequisites. You may want to install Zulu, a fully certified Java build as a package or manually.
Alternatively, Zulu Embedded can be installed for small systems either from the same package repository as above or manually. If you’re unsure which manual file you should download, using dpkg --print-architecture or rpm -q --qf ‘%{ARCH}\n’ rpm in your Linux terminal should point you in the right direction (e.g. armhf means ARM Hard Float).
When installing Zulu or Zulu Embedded from a .zip or .tar archive, make sure to set Zulu as the main Java “alternative”.
Note: Make sure to download Zulu or Java 8, as openHAB is not yet compatible with Java 9.
opus
(Jürgen Baginski)
March 27, 2018, 2:12pm
10
Zu is an alternative for Java.
Bredmich
(Michael)
March 27, 2018, 3:26pm
11
I´m now on Java 1.8.0_161 and myopenhab.org still says Offline
pi@HER-MB-OpenHab:~ $ java -version
java version "1.8.0_161"
Java(TM) SE Runtime Environment (build 1.8.0_161-b12)
Java HotSpot(TM) Client VM (build 25.161-b12, mixed mode)
pi@HER-MB-OpenHab:~ $ javac -version
javac 1.8.0_161
opus
(Jürgen Baginski)
March 27, 2018, 4:02pm
12
When creating the myopenhab account, you should have received an email which should have been answered for confirmation (if I’m not mistaken).
Bredmich
(Michael)
March 27, 2018, 4:08pm
13
I´m already logged in…
I already added the UUID and the Secret.
opus
(Jürgen Baginski)
March 27, 2018, 4:21pm
14
Did you expose any items to myopenhab?
Have a look into This old thread, the problem there was solved by exposing items.
Bredmich
(Michael)
March 27, 2018, 4:32pm
15
And how could i expose items in oH 1.8.3?
I just have a myopenhab.persist
Strategies {
default = everyChange
Items {
* : strategy = everyChange
The addon is org.openhab.io.myopenhab-1.8.0.jar
I already searched for newer version but can´t find any.
opus
(Jürgen Baginski)
March 27, 2018, 5:54pm
16
I’m sorry, but I forgot that such is possible via PaperUI and that belongs to OH2.
I guess I’m out of ideas. Sorry for that.
