It maybe something wrong with my system… just checking if anyone else is seeing the same…
I didn’t have time to perform my own troubleshooting, so this could be a false alert…
Using: openHAB 2.2.0 Snapshot build #1025 with the “mainstream” Z-Wave binding 2.2.0.201708281802 on a Debian Jessie with Oracle’s 1.8.0_144-b01 JVM)
My openhab.log logs an NPE ERROR:
29-Aug-2017 09:05:51.819 [INFO ] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
29-Aug-2017 09:05:51.953 [INFO ] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
29-Aug-2017 09:05:51.969 [INFO ] [al.protocol.commandclass.ZWaveSecurityCommandClass] - Update networkKey
29-Aug-2017 09:05:51.993 [INFO ] [ab.binding.zwave.internal.protocol.ZWaveController] - Starting ZWave controller
29-Aug-2017 09:05:51.993 [INFO ] [ab.binding.zwave.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
29-Aug-2017 09:05:55.181 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 1: Node found
29-Aug-2017 09:05:55.182 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 2: Node found
29-Aug-2017 09:05:55.182 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 3: Node found
29-Aug-2017 09:05:55.182 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 4: Node found
29-Aug-2017 09:05:55.182 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 6: Node found
29-Aug-2017 09:05:55.182 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 8: Node found
29-Aug-2017 09:05:55.182 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 9: Node found
29-Aug-2017 09:05:55.183 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
29-Aug-2017 09:05:55.183 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
29-Aug-2017 09:05:55.183 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
29-Aug-2017 09:05:55.183 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - # Nodes = 7
29-Aug-2017 09:05:55.183 [INFO ] [col.serialmessage.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
29-Aug-2017 09:06:00.745 [ERROR] [ab.binding.zwave.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
at org.eclipse.smarthome.core.thing.i18n.ThingTypeI18nLocalizationService.createLocalizedThingType(ThingTypeI18nLocalizationService.java:67) [108:org.eclipse.smarthome.core.thing:0.9.0.201708281632]
at org.eclipse.smarthome.core.thing.xml.internal.XmlThingTypeProvider.localize(XmlThingTypeProvider.java:128) [109:org.eclipse.smarthome.core.thing.xml:0.9.0.201708281632]
at org.eclipse.smarthome.core.thing.xml.internal.XmlThingTypeProvider.localize(XmlThingTypeProvider.java:1) [109:org.eclipse.smarthome.core.thing.xml:0.9.0.201708281632]
at org.eclipse.smarthome.config.xml.AbstractXmlBasedProvider.acquireLocalizedObject(AbstractXmlBasedProvider.java:211) [100:org.eclipse.smarthome.config.xml:0.9.0.201708281632]
at org.eclipse.smarthome.config.xml.AbstractXmlBasedProvider.getAll(AbstractXmlBasedProvider.java:165) [100:org.eclipse.smarthome.config.xml:0.9.0.201708281632]
at org.eclipse.smarthome.core.thing.xml.internal.XmlThingTypeProvider.getThingTypes(XmlThingTypeProvider.java:82) [109:org.eclipse.smarthome.core.thing.xml:0.9.0.201708281632]
at org.eclipse.smarthome.core.thing.type.ThingTypeRegistry.getThingTypes(ThingTypeRegistry.java:48) [108:org.eclipse.smarthome.core.thing:0.9.0.201708281632]
at org.eclipse.smarthome.core.thing.type.ThingTypeRegistry.getThingTypes(ThingTypeRegistry.java:59) [108:org.eclipse.smarthome.core.thing:0.9.0.201708281632]
at org.openhab.binding.zwave.internal.ZWaveConfigProvider.initialiseZWaveThings(ZWaveConfigProvider.java:310) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.ZWaveConfigProvider.getProductIndex(ZWaveConfigProvider.java:355) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.ZWaveConfigProvider.getThingType(ZWaveConfigProvider.java:382) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.advanceNodeStage(ZWaveNodeInitStageAdvancer.java:968) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.handleNodeQueue(ZWaveNodeInitStageAdvancer.java:230) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.ZWaveIncomingEvent(ZWaveNodeInitStageAdvancer.java:1306) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:567) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:250) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:214) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:208) [203:org.openhab.binding.zwave:2.2.0.201708281802]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1324) [203:org.openhab.binding.zwave:2.2.0.201708281802]
29-Aug-2017 09:07:26.373 [ERROR] [ab.binding.zwave.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
tagging @chris also (I hope it’s not a false alert )
