2018-05-10 17:31:14.084 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Study door open and/or garage movement and night time': 'reschedule' is not a member of 'org.eclipse.smarthome.model.script.internal.actions.TimerImpl'; line 78, column 5, length 50
Moving to a new odroid based system, and noticed this in my logs. This was previously running on a 2.1 system on windows.
Using the following call:
carport_light_timer.reschedule(now.plusMinutes(5))```
This hasn't been depreciated?
rule "Study door open and/or garage movement and night time"
Item alarm_zone_studyreed received update OPEN or
Item alarm_zone_garage received update or
Item unifi_Ugluk_Online changed or
Item unifi_Yumyum_Online changed
//Item alarm_arm_disarm received update OFF or
logInfo("CarportLights","Command Called")
logInfo("CarportLights","Weather_dayNight = " + weather_daynight.state)
if (weather_daynight.state !== NULL)
logInfo("Lights","Day/Night initialised: " + weather_daynight.state)
if (weather_daynight.state == OFF)
logInfo("CarportLights","It's not yet sunrise, and alarm turned off - turn light on for 5 mins")
zwave_switch_carport_lights.sendCommand(ON)
logInfo("CarportLights","Sent Carport lights their command")
if (carport_light_timer === null ) {
carport_light_timer = createTimer(now.plusMinutes(5))
logInfo("Lights","Carport Light Timer Ended")
zwave_switch_carport_lights.sendCommand(OFF)
carport_light_timer = null
} else {
logInfo("Lights",String::format("Existing timer, rescheduled for %s",now.plusMinutes(5)))
logInfo("CarportLights","End of rule")
} else {
else
logInfo("CarportLights","Its not night time")
else
logInfo("CarportLights","Weather_daynight has not been initialised")
Does that mean I want that whole createTimer line at the top of my rule rule (including the plusminutes?) I think I’ve always done it the way I posted and it’s worked.
